View Full Version : C6 Brakes
1bluaddict
11-12-2005, 11:17 AM
I have heard from a source that the C6 Calipers that are coming out this month and rotors will mount up to the C5 brackets. thats 14 inch front and 13.6 rear which would be killer. I was wondering if they will fit my Z06 wheels 18x9.5 and 18x12 and I hope it will work or I might have to go to 19's or 20's. Anyone out there know any thing about this new setup and if they will work, Bluaddict. :fingersx:
11-12-2005, 08:24 PM
ahhh its close but workable. You might have to run a small spacer.
Zo6 C6 thread (http://forums.corvetteforum.com/showthread.php?t=1189347&page=3&pp=20)
Andrew McBride
11-13-2005, 11:44 AM
I would love to know more this as well. I have a complete C5 kit w/ C4 rotors, but if I could upgrade to 6 pistons vs. 2...oh that would be nice addition.
sinned
11-13-2005, 03:30 PM
A quote from the thread Vince linked to-
I must say that I'm watching this mod very close. GM has a long rich history with warped rotors and if you ever owned a C3, you know this set up with warped rotors will pump air into your brake system. https://static1.pt-content.com/images/pt/2005/11/ack2-1.gif
As more C6 Z06's hit the streets, we will see of these OEM rotors are as good as the C5 aftermarket rotors...
Flame suit on!
Some people need to leave the tech alone, warped rotors pump air into a sealed brake system huh?
I have a set of these brakes already on order. I have spent some time over at that vette forum, some of the guys know something, but most of them don't...................
Ralph LoGrasso
11-13-2005, 04:18 PM
Who did you order them from, and what was the cost of everything?
datsbad
11-13-2005, 07:00 PM
also wondering?
427v8
11-13-2005, 07:06 PM
A quote from the thread Vince linked to- Some people need to leave the tech alone, warped rotors pump air into a sealed brake system huh?
Yes believe it or not the C3 4 piston brakes will pump air into the system if rotor runout is too large.
Too large is over .010" I think. The seal design has a lip that will roll back and forth on small movements and actually pump air inbehind the seal.
There are replacement O-ring seals that help that problem but they have their own problems.
Remember the brakes were designed in the early 60's and never updated!
Personally I run Wilwood SL4's on my C3..
And yes Yodi is right, some of them over on CF know something many dont!
ilovefirstgens
11-13-2005, 07:35 PM
haha i love how 90% of those guys just thought they looked cool.
but if they bolt right up to c5 hubs what about the afx spindle... hmm semi cheap huuuge brakes $1600 for the whole gettup dang!
so maybe ill be getting 18s afterall....
sinned
11-13-2005, 07:53 PM
Maybe a few very rare cases of OE 30 year old calipers but I have worked on hundreds of C3 vettes over the years with a variety of brake problems and have never seen that. In fact any car with deteriorated lip seals could do the same thing under the right conditions.
Also check that whole thread, a few of those guys have done their homework and you can put together a Wilwood setup for less money...of course it is far less blingy so I'm sure we don't care about that.
I'm not giving away any secrets..........but the brakes still aren't released, and they will be more than $1,700. You can't put together a cheaper wilwood kit, as the Z06 brakes are about $1,800 front and rear. You will need minimal 18" wheels. But the problem is that they are very wide calipers and require wheels with spokes that are far away from the center of the wheel. I don't think many peoples wheels are going to work with these brakes, unless you run spacers.
Problems with these Z06 brakes
most wheels won't clear without spacers
aluminum pistons transfer heat (opposed to SS pistons)
brake pads are very expensive and aftermarkets aren't out yet, and they are very thin, which also transfers heat, also they get cheese grated by the cross drilled rotors
both front and rear use 2 left hand rotors meaning both of the right rotors are going to be backwards and heat up faster than the left
stock front rotors are 25ilbs!!!!!
2 piece 14" rotors are only about 17-18 pounds but are about $800 for just the fronts
stock pads SUCK. aftermarkets arent' out yet, but expect to pay at least $400 for front and rear.
Good things
6 piston front 4 piston rear monoblock calipers with multi piston pads(20 brake pads all together)
14" front 13.5" rear rotors
looks really cool..........lol
I am buying just the calipers/rotors now, and getting aftermarket pads later. And also later will upgrade the front rotors to 2 piece rotors.
Ralph LoGrasso
11-13-2005, 08:20 PM
Good things
Pretty much everything you just said is in the thread Vince linked to. Nice summary, though. Why can't you post where you bought them from? Send me a PM if you don't want to post it.
ilovefirstgens
11-13-2005, 08:25 PM
t
wtf???
i didnt read all the posts about theese but why on earth would they sell them with just left rotors?
actually that info all isn't in that post. But if you do some searching over there all that info is from there. There are like 5 seperate posts about those brakes.
Ralph LoGrasso
11-13-2005, 08:30 PM
I've been keeping an eye on these brakes for a while now, so maybe I've read the info in multiple threads. All I would like to know is where you bought them. It's okay yody, don't worry -- you can still be the first on the block with them. These would be for my 4th gen, and since it's winter I wouldn't be purchasing them anytime soon, not to mention I get factory stuff at dealer cost. Appreciate the info, though. :squint:
hmmmmmmmmmmmmmmmmm.......................... :wedgie:
Ralph LoGrasso
11-13-2005, 08:33 PM
:slap: Thanks again!
how much room between your rotor mounting face and the backside of the spokes of your wheels? also the spacing on your back caliper bracket won't be right either, you would most likely have to space out your bracket or caliper.
Ralph LoGrasso
11-13-2005, 08:39 PM
I've got about 5/8" at the smallest point (closest to center) to about 7/8" at the farthest. There is a lot of room there due to the design of my wheels. The spokes cup outwards. I'd need custom brackets either way.
Not sure where your measurements are from, if that is from the caliper that might be enough room, if that is from the rotor face, that proabably isn't enough clearance, PM sent, you sore loser LOL
72SSAbody
11-14-2005, 06:47 PM
I've got the part numbers at work. If you want. PM me and I'll see if I can dig them up and forward them on. No reason not to share GM part numbers with guys/gals on here. :secret:
1bluaddict
11-14-2005, 07:15 PM
Thanks for all the info and feedback on something thats not even supposed to be out yet. Hey there Yody can you share that with me also :secret: mmmmmmmmmmmmmmmmmmmmmmm. Also 72SSAbody can you send me those part #s you were talking about. I am in the same boat as alot of you guys and bought the C5 kit for my 6/71 blown 78 Z28 cuz I really believe in Mores Law " Bigger Is Better " and I want to be able to throw someone through the windshield when I hit those puppies hard. No one has been able to get that $100 dollar bill off my dash when I got my foot in the gas, deep in the gas, Yeah! Someday it will be rolling again as I got some work injuries that are holding me down right now, but I am collecting lots of parts so when I am ready I can keep workig til its done, well I just might never be completely done as there is always something new I just can't live without. I guess it means I'm a true Gearhead or I'm working on it, Enjoy Claude.
I was just messing with ralph. There is no release date on the brakes, latest I heard was end of december. When I get the set I ordered(on backorder) I will be happy to take pictures and lots of measurements. I can be the guinea pig. THe biggest thing about these brakes is that most guys wheels will NOT clear these things as they are super wide calipes.
Ralph LoGrasso
11-14-2005, 11:12 PM
Vince actually just sent me an email with them, I do appreciate the help though. Feel free to post them in here for others, or I can also do it.
1bluaddict
11-15-2005, 10:18 PM
Thanks for yankin my chain there Yody and it looks like we are all in the same boat just waiting for the new parts:doh: . I think I will stick my nose:hand: over in the Corvette Site and I might just get lucky, Enjoy Claude
72SSAbody
11-17-2005, 02:48 PM
Good to hear!
Joe
ilovefirstgens
11-19-2005, 07:47 PM
Part numbers (gotten off corvette forum so cannot confirm)
2006 Z06 brake calipers
FR: 19121789
FL: 19121788
RR: 19121803
RL: 19121802
Rotors
Fr: 19121787
Rr: 19121797
Pads:
Fr: 19121809
Rr: 19121811
i think he got the pads wrong no way it costs $800 for a full set of pads?!
P.S. if the pads are both sides the grand total comes out to $1765 shipped from gmpartsdirect a steal if you ask me!
Jimmy Sean
11-21-2005, 07:06 AM
Here is a link to gmpartsdirect with part numbers and prices.
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=C6
ilovefirstgens
11-25-2005, 06:49 PM
so the question now is how the hell are we gonna set up the rear callipers and parking brake.... and where am i gonna squeeze another $2500 out of my budget......
Ralph LoGrasso
11-25-2005, 07:53 PM
Precision Brakes "Mr. Parker" should solve the problem with the parking brake.
Parking Brake Caliper on PB homepage (http://www.precisionbrakescompany.com/)
the parking brake is inside the rear rotor, just like a C5,C6 or 4th gen. I am waiting for all the guys to buy these brakes, to find out that almost all wheels won't clear the brakes. I have also heard a lot of bad things about the design of these brakes. A lot of the interest is because of the bling of these brakes. However I still don't believe everything I have heard read about them and will still be running them, my biggest concern is the front rotor weight. I will buy the GM rotors first(only like $75 each) and later upgrade to some 2 piece rotors. ETA on some of this stuff is late december, so keep a look out
ilovefirstgens
12-04-2005, 11:26 AM
Ditto with the rotors, 25 lbs is rediculous!
and as to getting them to fit ill be running c6 wheels with adapters so ill have more than enough room until i can afford some custom wheels that will clear.
for the front i was just thinking to go ahead and buy the afx spindle, having just recieved an oil pan and some brackets from the ats guys i know i will be more than happy with the spindle, their work is simply gorgeous!
I cant seem to find how to mount the rear calliper though, any tips are appreciated, and now that the car is stick i don't need an e-brake anyway! haha
ProdigyCustoms
12-05-2005, 07:57 PM
Uh no, He will not be first on the block
ilovefirstgens
12-05-2005, 08:09 PM
oye please dont tell me thats how they come from from gm.....
P.S. Frank did you guys give up on gpsuperstore or what?
ProdigyCustoms
12-05-2005, 08:13 PM
Nope, vacation, look for a bunch of GPs this week. No, these are none engraved
looks like the same pictures PBR emailed me when i inquired about them?? Well maybe you actually do have them first, too bad you paid $1,400 for just a front set of cailpers! :enguard:
4MuscleMachines
12-05-2005, 09:27 PM
wtf???
Read here for the only left rotors available issue. No right hand rotors from GM for the Z06.
http://www.z06vette.com/forums/showthread.php?t=90293
so far it hasn't been an issue, apparantely there will be no right hand rotors, so if that really bothers you, do yourself a favor and buy aftermarket rotors. However if your not a the track, it won't matter either way.
ProdigyCustoms
12-06-2005, 02:17 AM
No, I promise that is not a pic from PBR, those shots are taken right here in sunny Orlando, Florida with my own little camera. And what would make you think I would pay anything for the first set of calipers! Forget it, don't answer, that is really more of a statement then a question.
4MuscleMachines
12-06-2005, 10:56 AM
so far it hasn't been an issue, apparantely there will be no right hand rotors, so if that really bothers you, do yourself a favor and buy aftermarket rotors. However if your not a the track, it won't matter either way. I know what I have to do without you ever letting me know. I wasn't replying to you but merely answering the question from Ilovefirstgens.
For the record, it doesn't bother me and I am already ahead of you. I already did myself "a favor" and purchased a new C6 Z06, my second Z06. I think I know a little more about these cars and their brakes due to first hand experience owning Z06's.
Wow, another rich hero! This isn't a race to see who gets brakes first, and how does owning a previous z06 make you an expert on the new brakes?? Not that I really care either way. Have fun with the 6 month waiting period on your z06, maybe SW will sell you one of his extras?
ProdigyCustoms
12-06-2005, 11:04 AM
OUCH!!!! 4MuscleMachinesMan = 1, Yodster = 0
Lol......if I really wanted to get on the scoreboard, I would probably get the boot at the same time!
zbugger
12-06-2005, 12:36 PM
Don't worry, you will. :angel:
runup or shutup, is the moto I go by, I think it applies here :)
ilovefirstgens
12-06-2005, 05:49 PM
wow everyones gotta take a chill pill!
haha, and now i feel the same as Cody, thought i would be the only guy on the block with em if i get theese brakes but word around town is that this ******* kid (2 years older than i) trust fund baby is waiting for his c6 z... ugh
for lack of a better term, "Why can't we all get along?"
protour_chevelle
12-06-2005, 05:59 PM
Holy fruitloops theres a ton of contradictions going on here. I think we need a debate section that will allow an all out get what you want off your chest area. It would be an insane read!
Someone is always going to have more money then you, more toys, more hoes, more greenbacks. Jealousy is attacking the best of some of you. I try my hardest not to compare my car to others, if I did I would find myself in a costant state of depression. Who cares if that kid has a C6 Z06. Live your life instead of trying to live his.
Rant off.
-Matt
gearheads78
05-24-2008, 12:32 PM
delete
