View Full Version : Blinker not blinking
jlwdvm
09-23-2016, 09:55 AM
I have a AAW Power Plus 20 wiring harness in my 69 firebird project. My headlights work fine, the motor runs fine, etc. I am going to use the front turn signal-parking light area for a brake cooling duct opening, so I purchased a set of halogen headlights with LED turn signals in them. When the turn signal is supposed to be on (GM Tilt rebuilt column) I have 12 volts and the turn signal comes on, but doesn't blink. Thoughts?
Rod
09-23-2016, 11:29 AM
the LED light has no load on the wiring system to run the flasher, you will need a no load flasher that is grounded and then they will work
MonzaRacer
10-15-2016, 05:48 PM
electronic flasher ftw
or the blinker fluid is too low.
http://kalecoauto.com/index.php?main_page=product_info&products_id=22
Dark Pursuit
10-16-2016, 04:44 AM
No load flasher is required in turn flasher position of the fuse block at the top left . This one does not require ground wire, The Emergency flasher will require a no load flasher with a ground wire in the bottom right of the fuse block.
scott67ss396
10-21-2016, 08:00 AM
I have the Led as well for the Front in my AAW, changed out the flasher unit to a LED one but now when the head light come on they wont blink the just glow?
Ron Sutton
10-21-2016, 12:00 PM
I agree with Monza. The key is quality Blinker Fluid like this:
133281
:cheers:
Dark Pursuit
10-21-2016, 03:11 PM
Do emergency flashers work ?
