View Full Version : 2013 camaro tac module?
timopajala
09-23-2016, 09:24 AM
Does 2013 camaro have tac module or is it tps system that sends the info To pcm and then To throttle body? Im doing swap and have the original harness etc and need little More info about the electrics.
amargari
09-25-2016, 11:39 AM
I don't believe that the later controllers have TAC modules. I believe that the DBW is controlled by the CPU.
andrewb70
09-25-2016, 02:44 PM
The Gen IV electronics don't use a TAC module. There is a plug right off the ECU that goes to the pedal.
timopajala
09-26-2016, 06:47 AM
Thank you very much for the info! That clears a few things :) By the way, is the overflow tank pressurised or not? Im thinking of using my old reservoir but it dont held pressure.
