View Full Version : TKO-600 5speed Tremec plus plus plus
Razzor67
09-16-2016, 12:04 PM
For your attention a new TKO600 / plus 90% of what you need to install it.
Lakewood bellhousing,custom drive line,new lu 04020 clutch and flywheel,clutch fork,McLeod adjustable ball stud, McLeod hydraulic clutch TO bearing, billet aluminum remount mount reservoir,modified GM clutch master cylinder if I can find it. Maybe a few more items to go with this I need to sort out the rest of the pile.
I have decided to go the LS way so everything I've purchased over the last few years is going.
Looking for $4000 for everything. You pay the shipping.
Thanks Ray
yellow1098Greg
09-19-2016, 01:56 PM
hmmm wonder what else id need for a 2nd gen TA and what shipping would be to central florida?
Razzor67
09-20-2016, 10:04 AM
I believe the shipping will run about $250 as far as what else you may need . Maybe a drive line this one was custom built for a 67,68,69 f-body. Everything else is bolt on.
Thanks Ray
Shizzle
09-20-2016, 12:52 PM
Interested in selling just the trans?
Windycity1
09-20-2016, 03:22 PM
The TKO 600 will work with an LS.
Razzor67
09-20-2016, 07:10 PM
I believe it will. Maybe someone has more knowledge on that then I do.
Tim john---
09-21-2016, 02:22 AM
I installed a TKO-600 to a 2004 GTO LS1 in a 69 Firebird, no problem at all. Purchased the correct bell housing and it was as simple as bolting it up, effortless.
Tim john---
staged67gspwr
09-22-2016, 05:01 AM
would you sell just the trans?
MangeMD
09-22-2016, 08:13 AM
My neighbor has this trans in a 68 Camaro with a twin turbo LS. Bolted right up with the correct bellhousing. Works like a charm.
udloze
09-22-2016, 06:37 PM
what ratio trans? Road race or street thanks AJ
Razzor67
09-23-2016, 07:00 AM
Tko-600. TCET 5009 fifth gear 0.64 :1 /fourth gear 1.00:1 /first gear 2.87 :1
staged67gspwr
10-23-2016, 05:36 AM
tranny sold??
Razzor67
10-23-2016, 06:34 AM
Still here however I do have a discussion going with someone. I'll let you know if it falls through.
staged67gspwr
10-23-2016, 06:36 AM
Cool thank you
67buckeye
12-25-2016, 04:46 PM
Is this still available? Thanks
ehummelman
01-03-2017, 10:04 AM
If you sell the trans separately I might be interested in the hydraulic clutch stuff and bellhousing. I currently have the same trans but would like to ditch the zbar setup.
32deucecoupe
01-07-2017, 07:03 AM
T56 from a 2004 GTO, part of LS1 a pull out package i purchased for the project, hope to drive it this year.
Gmc427
01-21-2017, 12:31 AM
hi, still available? regards
Razzor67
01-23-2017, 07:57 AM
Pm sent
