View Full Version : Late model steering column?
DreKoushRanada
09-14-2016, 11:13 AM
Will a 2006 GTO steering column or any other late model column work in a 1970 Cutlass? I plan on changing out the Steering box to a Jeep one or so also.
Mr Nick
09-15-2016, 02:36 PM
While almost anything can be made to work, the column from a late model GTO won't bolt in by any means. If you're going through the trouble to modify a late model column to fit, I'd also suggest a better upgrade than a Jeep steering box.
DreKoushRanada
09-16-2016, 07:48 AM
Is Lee steering boxes back up for sale? I will look into some better alternatives.
ccmc
09-16-2016, 08:01 AM
You can probably use a 3rd or 4th gen camaro column. They still used a round column vs the newer rectangular plastic versions. I installed a modified 1989 column with a 2002 wiper controller in my 1969 camaro.
You will have to change out the firewall mount and I used my original dash mount bracket after grinding a relief for the high beam activation rod.
Rick
Mr Nick
09-17-2016, 08:14 PM
I think Lee is now... http://www.steertechgrp.com/
or check out http://www.turnone-steering.com/
130fe
09-18-2016, 04:10 AM
I think Lee is back in business.
DreKoushRanada
09-19-2016, 07:59 AM
Rick
I will be looking into that. Thanks
