View Full Version : I Sucked my throttle plate !
FANTM58
09-07-2016, 07:56 PM
Yep ,, it sucked !! ( pun intended )
1/2 of #6 throttle plate broke in half
and sucked into the cylinder .
as of now, it's suck in between the intake and exhaust
valve. It was in the cylinder , no damage to the piston or
walls,,YAY!! I'll just ball hone the cylinder a bit.
i need to remove my valves to check them and the seat.
andrewb70
09-08-2016, 05:41 AM
Got lucky. What intake system is that?
Restomod
09-08-2016, 06:23 AM
WOW! Looks like its brass, probably the only reason it didnt hurt anything.
jlcustomz
09-08-2016, 12:00 PM
Coulda been worse, but that still sucks.
In my case, it blew. I made an exhaust cutout valve out of a large throttle body years ago. Worked pretty good (cable operated) till for some reason the throttle body shaft snapped & blew out the plate & part of the shaft. At least it was on the exhaust side.
FANTM58
09-08-2016, 05:06 PM
its a MOMAR there no longer in business,,
and its aluminum,,
I took it to my machine shop today,,the intake valve was bent a bit,,but thats it...
jaybee
09-10-2016, 07:33 PM
Wow that was really fortunate.
