View Full Version : header help on a 63 impala. looking for a tight, high fit.
oldskoolss
08-30-2016, 06:38 PM
I'm looking for what mid length or full length header the protouring guys end up using that don't hang down to drag. I'm running a 2 inch drop spindle and qa1 coilover up front. Ride height isn't set in stone, but it needs to be low. Any of you guys have a recommendation?
65 drop top
08-31-2016, 10:33 PM
What motor are you running? I've had good luck with Sandersons and Lemons.
oldskoolss
09-01-2016, 10:11 AM
it's a standard sbc. aftermarket heads but no angle to the plug. I'm trying to stay away from block huggers if at all possible. I've been looking on both of those websites. I need to call both of them maybe. what are you running on your 65?
65 drop top
09-04-2016, 11:42 PM
I had a 427 with Sandersons. I swapped that out for a 502 with AFR heads with raised exhaust ports so the Sandersons didn't fit anymore. Picked up a set of Lemons for it. Both sets of headers fit nice, but the Sandersons were 3/4 length. They were much easier to install.
