View Full Version : Low Mounted AC with SpeedTech Subframe?
Dave95Z28
08-29-2016, 09:55 PM
Has anyone modified a 1st Gen SpeedTech Pro-Touring Subframe to allow them to low mount a Sanden AC compressor?
I have a LSA motor I will be installing in my 69 Camaro and I would like to use the GMPP Parts modified LSA Accessory Drive Kit. None of the other accessory systems appear to use a separate belt for the supercharger or appear to have very good way of driving the supercharger at higher boost levels.
People using the accessory system I would like to use have successfully notched and boxed the factory subframe and DSE subframe. Just trying to find out if any one has successfully modified a SpeedTech subframe.
Dave
killer69
08-30-2016, 06:26 AM
Dave
Normally we would modify the subframe to fit the compressor, we have done 5 or 6 over the years. Give Kwik Performance a call they have a new bracket set up for the LSA I think?? that uses an even smaller compressor and that may require no or little modification.. the other option although more expensive is Drive Junkies last I herd was working on a front drive with a high mount A/C .
slimjim
08-30-2016, 07:25 AM
would the low mount compressor on a 5th gen LS3 be the same or similar story as on the LSA?
Dave95Z28
08-30-2016, 09:39 AM
You don't happen to have any photos of the mod'ed subframe? Good to know they can be mod'ed. I am very anxious to get started putting the LSA motor in the sub and ordering some of your 2" headers.
Dave
silverr1ride
08-30-2016, 03:42 PM
Concept One has a new system
http://www.c1pulleys.com/car-pulley-kits/chevy-pulley-kits/chevy-ls-kits/chevy-ls-supercharger-kits.html
