Schroeder
08-14-2016, 08:45 AM
Hey guys, I have a question on body flex on my 77 firebird TA. I recently cut out the frame rails on my 77 TA and replaced them wit home made tubular ones. I cut out the inner wheel tubs too because I am mini tubing the car. The tubs and rails were not out at the same time. I had bracing inside the car made out of tubing. the tubes go from a to b pillar and were connected width-wise across the car too. The DS door has been open for months because I had the door panel on and the window crank. Just so happened the window crank came in right on the tubing braces inside so it has been unable to close.
I took the crank off today and the door will not close. prior to this project the door did close. Now it's not even close. The door tries going down. I was pushing on it the door skin popped in for a second, and the door still would not close! Striker looks to be 3/8" - 1/2" lower than the door latch. The car was supported on the front subframe, rear rocker panels because the frame rails were cut out, and on the trunk pan supports at times. The rear window and windshield are in. Car has hurst t-tops. T-tops are in. I find it hard to believe the car flexed so much. The striker does appear to be moved downward, but that could be from the last time the doors were aligned. The striker is tight, but maybe I did bump it hard in the last months and force it to slide down.
Does anyone have a good way to check and double check to make sure everything is still square? I need to redo the quarters, trunk, and do a roof swap. With all that work coming up I need to make sure I'm currently sitting in a good spot. Thanks.
