View Full Version : CTS-V Brake Calipers
PD-1969
08-13-2016, 08:27 PM
Hey all,
I have a set of CTS-V brake calipers that are from the 2009-2014 CTS-V. These are from my personal car (I switched mine out for yellow ones) and they have around 12,000 miles on them. I know that LSX Concepts sells adapter brackets for Ridetech spindles and Ford 9". I would like to get $800 for them. They are located in Perry, MI. I would prefer local pick up but can also provide shipping at the buyers expense.
If needed I have a set of OEM rotors that I can sell with them for an additional cost. The rotors came off when the calipers did; they will need turning and the rear rotors have small hammer marks in them. I may be able to provide a set of R1 Concepts slotted rotors instead depending on when I do my brake job. Those would also need turning.
130563130564130565130566130567
PD-1969
08-23-2016, 06:47 PM
Bump
PD-1969
03-30-2017, 10:02 PM
Bump
Charley7
04-04-2017, 02:51 AM
What size rotors are they for ? I wonder how I figure out if they will fit my 18" wheels.
Charley
simon455
04-04-2017, 04:40 AM
My 18"x9.5" forglines none step lip clear my zl1 brake set up with a 1/8" shim.
Zl1 uses same caliper with I think even bigger 2 piece rotor than ctsv
Charley7
04-04-2017, 01:02 PM
My rim is a soft lip. I had the ctsv 4 piston fronts and they wouldn't clear. The 6 piston is a different looking caliper.
I've emailed my rim company to see.
Charley
