View Full Version : 1969 camaro coil overs
RichieRath
08-11-2016, 05:10 PM
Looking for 1969 camaro front coil overs.
Dark Pursuit
08-11-2016, 05:27 PM
Look at Speedway but motors for QA1 bolt in kit. Easy bolt in , I did have to drill and tap for larger bolts in lower a arms, but otherwise you do need to know which springs to use, and did not come with slip washers for adjust nuts
RichieRath
08-18-2016, 04:47 PM
Thank you
Typhoon1015
08-18-2016, 04:51 PM
anything in particular you are looking for coilovers for? ride? adjustability? what are you planning on doing with the car? I would recommend looking into a Viking Performance kit. Double Adjustable with high quality springs with whatever desired spring rates and very competitively priced.
some more info will help us steer you in the right direction.
RichieRath
08-19-2016, 12:18 PM
1969 camaro stock subframe and cpp tubular control arms just minor auto x in future nothing harsh
