View Full Version : 2" inch drop base or greater for Holley carb needed
keith4909
08-08-2016, 05:07 PM
I can't find a 2" or greater air filter base drop. I can't modify the air cleaner. I will have to find a proper base drop or go with a different style filter. I head of the l88 corvette base but not sure if specs. Any help would be great. Part numbers would be helpful too.
CliffsBlueCamaro
08-09-2016, 04:19 AM
I couldn't find a 2" drop either. I went with this 1.5" drop from Allstar because it was just $15. --> http://www.speedwaymotors.com/Sure-Seal-Air-Cleaner-Base-Only-14-Inch,29473.html
If it didn't clear with a 3" tall filter, then I was going to get a 2.5" paper filter and try it out. (Purolator PN A60102, Fram PN CA342, NAPA 2102, Wix PN 42102)
Hope this helps!
68Cuda440
08-09-2016, 09:07 PM
This is what I used to run w/ my Barry Grant. This is about 2" drop with a 3-1/2" filter. 2-1/8" above the flange and you can not have a choke tower. http://www.knfilters.com/search/product.aspx?prod=61-4500
keith4909
08-09-2016, 10:30 PM
I found one with a 2" drop and one with a 3.5" drop. First one was allstar and the second was moroso. The only issue with the moroso is it's an offset flange. Orders both and will keep the best one. Thank you
CliffsBlueCamaro
08-10-2016, 06:43 AM
Well dang, I must've not looked hard enough! LOL
Glad you found one that works. This is good info for others who are looking.
keith4909
08-10-2016, 10:27 AM
I'll list part numbers once I get them and if they fit.
F-Body International
08-13-2016, 08:01 AM
Talk to Dave at Pro-Touring F-Body. He has a lot of experience with the drop base air cleaners and also has a few different drops that he supplies for the F-Body shaker cars. He'll probably be able to put together a low profile air cleaner that still flows well for you. I know the latest PTFB Trans Am drop base shaker kits have been flowing over 1000cfm.
http://www.pro-touringf-body.com/engine.html
