View Full Version : Holley Id
toofun
11-10-2005, 02:30 PM
How do I identify which carb I have. It has no air horn at all on it and no metal tag? It is a Holley and it definately is a 4 barrel carb. Where would the numbers be to identify it and how many numbers should their be? It also has two metering blocks on both sides.
Thanks In advance.
Mark
TOOFUN
toofun
11-11-2005, 05:03 AM
Here is the link to the pictures I got for the carb. Horn was definately NOT MILLED OFF. It is as clean as you will every see with no milling or cut marks. Definately came without the air horn and choke. ANY INFO as detailed as you could get would be appreciated. Still can seem to find ANY numbers on this carb!! Only thing on it is a sticker fro CEC fuel systems in clearwater FLA.
http://pg.photos.yahoo.com/ph/draggingmedowntoo/album?.dir=25de&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos
11-11-2005, 08:02 PM
looks to be a 650...can you remove it and measure the thottle blades? The size would desiguish between a 650 and 750. 750-850's are the same size.
