CamaroJesse
08-07-2016, 09:28 AM
i Started my 6.0 swapped firebird yesterday for the first time. The car starts but dies after a few seconds. I just hooked up a pressure gauge to the rail and it read under 5 psi. I have a Ricks restomod tank with 5th gen camaro pump. one fuel line from the tank to the rail since no return is needed for this application. grey wire to power and black to ground. pump primes and stays on while in run position. fuel is making it to the rail but no building pressure. at no time is the pump turning off. if it matters i am using holley hp efi.
thanks!
thanks!
