View Full Version : LS 3 swap 69 Camaro New Gauges install
DT69Cam
07-29-2016, 04:33 PM
Hello guys, new member here. I'm wiring up my New Vintage USA gauges in my LS3 swap 69 Camaro. My gauges need a positive 12v trigger source to light the warning lights in the new gauges. The parking brake is a negative trigger I'm sure. Also the Check Engine Light (GMPP harness) I believe is a negative trigger as well. Can I use a Bosch type relay to reverse polarity and convert them from neg to positive ?? Thx!
Schwartz Performance
07-29-2016, 08:51 PM
Yeah just use a standard relay that switches when ground is introduced.
DT69Cam
07-30-2016, 03:47 AM
Thank you!!! I was thinking a Bosch type 30a relay was too much.
dhutton
07-30-2016, 03:55 AM
Dale, have you ever driven a Bosch 30A relay with the MIL signal? The relay coil current is 160 mA which seems high for a signal intended to drive a 15 mA LED....
Not saying it doesn't work, would just like to know if anyone has actually done it or knows the current sink capability of the MIL line...
Don
Richard454
07-30-2016, 05:10 PM
Here's a cleaner way to do it- can find for less than $20- "Universal Trigger Output Module" TR7-pac
Programmable -can take the inputs- swap polarity-pulse to constant or constant to pulse- latch-timed etc- really neat piece.
Instructions- http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
https://static1.pt-content.com/images/pt/2016/07/tr7_m-1.jpg
If you want/need more - here's the "pro" version- about $35 but totally programmable w/ a USB port
https://static1.pt-content.com/images/pt/2016/07/TriggersTimersPAC13TR7PROdetailedimage1-1.jpg
dhutton
07-30-2016, 05:19 PM
Instructions- http://www.pac-audio.com/PACProductData/TR7h/1_Instructions/tr-7_instructions_010505.pdf
That is really cool!
Don
DT69Cam
07-30-2016, 05:27 PM
Awesome!!!!! Thank you. I just have to figure out how to wire it up LOL. Feature#1 I would think.
Richard454
08-02-2016, 03:12 PM
It's a really cool problem solver. Got mine off eBay for less than $15 shipped. I wanted a single momentary switch (SPST- single pole single throw) to control my door locks. One push- doors unlock- two pushes within 3 seconds -they lock.
Works great!!! No latching relays to stay on and pull power -AKA parasitic draw on the battery. It was smaller than I thought it would be- easy to program with LED confirmation.
Richard
https://www.youtube.com/watch?v=b3BnJinrprQ&feature=youtu.be
DT69Cam
08-03-2016, 10:43 AM
Richard
Very cool, THX!!
