atl
07-19-2016, 01:39 PM
so i have a 1999 motor, harness, pcm. and have two electric fans that i just wired up, and am have some problems with.
this car has air conditioning as well.
Im using a three relay harness that i put together, using this diagram:
https://static1.pt-content.com/images/noimg.gif (http://s951.photobucket.com/user/picturebucket42/media/ls1coolingfansbu6.gif.html)
I am letting the pcm, tell the relays when to go from high speed to low speed and vis-versa.
these are the pin points that i used on the back of the pcm.
blue connector pin # 42 for low speed, and red connector pin #33 for the high speed.
so this is whats happening, 1) fans don't turn on by themselves(i need to unplug and re-plug them) and even when unplug and replugging only one fan will turn on. 2)fans don't turn off. 3)the one fan only runs on high
I also found this other 3 relay diagram, difference that i can see is where relay 3 and 2 ground.
https://static1.pt-content.com/images/noimg.gif (http://s951.photobucket.com/user/picturebucket42/media/313.jpg.html)
where should i start looking to find the problem?
