04ctd
06-23-2016, 02:34 PM
1034 miles on the car/motor/tranny
this is a great quality "driver" car to me, something that you could drive and enjoy.
blow the tires off at a stop light and not be afraid of rock chips tearing up the underneath.
with the overdrive and 4 wheel disc, it's great car to use as a DD if you have good weather, or a place to stash it at work (parking garage?)
IDK, either way, it's loud & fun.
PM me if you want to know the reserve, the reserve is mid-range of what other cars like this are priced on ebay, so it could be a steal, as this car has a LOT more "quality" features than most other kit cars.
http://www.ebay.com/itm/-/162113447140?
34 Ford Kit Car.
Kit Frame, fully smoothed and painted/powder coated
Automatic with overdrive
Four wheel disk brakes.
Fuel injected.
Fully painted: frame, suspension, rear end, brake calipers, shocks,
Power brakes.
Motor:
GM Crate Engine, 351hp/400tq, Fuel Injected,
Aluminum roller rockers / 1.6:1
Electric fans.
MEFI 4 engine controller with GM wiring harness
Serpentine accessory kit, chrome
Vortec style heads/intake
Exhaust:
Black flow master
Ceramic coated shorty headers.
Fully welded
Side exit with custom tips, right before rear wheel.
Interior:
Chrome fire extinguisher (on transmission hump, in case you spot it)
Chrome Tilt column.
Grant steering wheel.
Heat
Vintage Air
Transmission:
Built 700R4 with overdrive.
Drive shaft loop.
Lokar dipstick.
Rear End:
Ford 9 inch, Fully braced
Rear disk brakes.
Steel braided brake lines.
Electric solenoid to raise/lower the license plate.
Chrome:
Alternator
Oil pan
Tranny pan with plug
Power steering pump.
Pulley set up
Starter.
34 Ford Kit Car.
Fuel injected.
Power brakes.
Motor:
Electric fans.
Exhaust:
Black flow master
Fully welded
Interior:
Chrome Tilt column.
Heat
Vintage Air
Transmission:
Drive shaft loop.
Lokar dipstick.
Rear End:
Rear disk brakes.
Chrome:
Alternator
Oil pan
Pulley set up
Starter.
