View Full Version : epoxy/glue needed for replacing studs in camaro spoiler
130fe
06-18-2016, 11:12 AM
I am try to replace a few of the studs in my factory camaro spoiler. i have the stud kit but don't know what I should use to keep them in the spoiler. The studs are steel and the spoiler is fiberglass ( I assume). Any help would be appreciated!
dhutton
06-18-2016, 12:39 PM
JB Weld or 2 part panel adhesive will work.
Don
HotRod47
06-19-2016, 02:46 AM
I have, and would suggest using Six10 Epoxy form West Systems. It is a two part epoxy that will never come apart.
Rick Dorion
06-20-2016, 02:04 AM
I've used JB Weld with good results.
130fe
06-20-2016, 02:44 AM
Thanks for all of the recommendations!
MonzaRacer
08-23-2016, 03:49 PM
I have fixed few 'glass parts by taping out holes or rebuilding with resin or fiberglass resin jelly.
If reinstalling studs, resin or 'glass would be my choice.
Drilling and/or taping solid fiberglass is pretty easy. You can also use resin for "loctite" if boss
is damaged the resin jelly is ideal.
jlcustomz
08-26-2016, 08:25 AM
ANY of the above suggestions done correctly should be stronger than the original somewhat fragile aged frp material would be anyways.
Two part panel adhesive with their instant mixing tubes & a proper 2 part application gun are a great choice for someone with a gun that regularly uses this stuff, Big expense if ya don't. I recently got a proper gun & some of the smart line adhesive from Finishmaster at Beach/ southside blvd at a decent price. Smart line adhesives are 30 something per tube instead of 40 something for the 3-m & seem to be about as good. I think their gun was around $40, rather than near $100 like I used to see some of these fancy caulk guns going for. Pretty much shoot it in the hole like you would caulk.
West marine stuff is great, but a little overpriced due to all the middlemen involved.
Traditional fiberglass resin & jelly is great as long as it's fresh enough & you may need to buy a lot more than you need for a small project if you don't have other uses for it before it goes bad.
JB weld is an epoxy that has been around forever, easily bought in small quantities & may be a better choice for you IF you don't already have or can use the other listed choices for other stuff.
130fe
08-26-2016, 10:35 AM
I ended up using the 2 part JB Weld and it worked out great!
