View Full Version : NICOPP in straight line?
badazz81z28
06-12-2016, 06:18 PM
Anyone where to buy NICOPP in straight lengths upwards to 8-10 feet? I see you can buy long coils, but doesn't make much sense to buy that much and a $$$ straightener for a one time use.
I've seen it hanging on the brake line rack at Advanced/CarQuest stores. Don't know about 8' - 10' long though.
Bob.
badazz81z28
06-13-2016, 07:25 AM
Bob.
With a quick Google search seems all the big names carry the brand but nothing in that material or the 72". I may have to special order it
FlatWhiteLark
06-13-2016, 06:00 PM
You don't need to buy a straightener, you can straighten it pretty easily and if you need 10 feet buy a roll and sell the remainder to someone else. Or buy a straightener and resell it for 20 bucks off.
badazz81z28
06-13-2016, 06:22 PM
I don't want it to look like crap.
raustinss
06-13-2016, 07:50 PM
build a straightener .....do a quick google you will find plans ...cant remember where i found mine but , all it was, was a few sets of screen door rollers and 2 pieces of angle
vintageracer
06-14-2016, 05:55 AM
"Curves" are in! Make it a part of your design.
Apogee
06-14-2016, 12:14 PM
The longest lengths of straight tubing you'll find will generally be 72" due to parcel shipping size limitations, although that isn't to say that you couldn't do a 180 degree bend and have numerous 72" lengths. That said, a "straightener" can be as simple a drilling a hole through a 2x4, clamping it in a vice and pulling the tubing through it. UHMW nylon cutting boards work even better IMO. And while a roller style would be ideal, like you said, that's a lot of $$$ for one time use.
Alternatively, call your local hydraulic shop and see if they have a straightener that you could borrow, rent or just let them straighten your tubing for you.
Tobin
KORE3
badazz81z28
06-24-2016, 06:02 PM
Tobin, bought some line and totally forgot fittings! Now I noticed the NICOPP pre-flared came with black fittings. Are the particular for NICOPP over the brass colors?
MonzaRacer
07-31-2016, 05:25 PM
Trust me, as a tech I prefer 72 in straight lines. Back at Midas I used to only order 72 in inverted flare line, in steel from NAPA as the Nicopp hadnt made a big presence yet.
Any longer makes it hard to deal with.
Since I bought my hydraulic flaring tool, cutting ,flaring and installing lines for me is an art form personally. I try to make my lines form to original space and hangers.
TRUST ME, ANY LONGER TURNS INTO A NIGHTMARE. Period.
After having re lined 2000s Silverados front to back it makes things easier.
I cut to fit and hand bend everything, and having done it for so long I hate roll line.
