View Full Version : 1969 Subframe w/C5 Brakes, 12-bolt 3:73s w/C5 Brakes, Ricks Tank w/A1000
l2azorback
05-31-2016, 08:09 AM
Hello,
I have some parts that are like new, with ~2k miles. I am switching over to a complete DSE set-up. The parts are currently at V8 Speed and Resto in Rosebud, IL where the car is currently undergoing the DSE conversion. Shipping will be on you, and can be coordinated with V8 Speed and Resto (or local pick-up). Pictures are available on the 3rd tab via the link below:
You can see the ride height of the car in the included pictures. Here are the specifics:
Complete Factory Subframe $3500
- AFX 2" Drop Spindles
- Global West upper A-Arms
- New Steering Gear Box
- All new Steering linkage
- Swaybar
- C5 Baer brakes with 13" drilled slotted rotors
- NO motor mounts
Complete Moser 12-bolt rear axle w/brakes $1850
- Auburn Posi with Richmond 3:73s
- Factory axles w/c-clips
- C5 Baer brakes with 11" drilled/slotted rotors
- Global west lowering springs with 3/4" blocks
- Custom diff cover with bearing supports and ARP hardware
Ricks Stainless Tank with notched corners (16 gal) $1500
- Aeromotive A1000 in tank pump
Wheels/Tires pictured $1850
- Intro Malibu Wheels (powdercoated black)
- 18x10 rear with BFG KDWs 275s
- 18x8 front with BFG KDws 245s
- ~75-80% tread
Payment Options: Certified Check, Postal Money Order, Wire Transfer (I may be able to work out something with V8 Speed and Resto for a direct bill to you where you can use your credit card/checking account - Will discuss with Kelle Oeste - May be a handling fee?)
http://v8tvshow.com/V8TV_2/index.php/car-build-photo-galleries?view=goldpicasa&album=6257870902911976177&userId=100048221976759975667
(http://v8tvshow.com/V8TV_2/index.php/car-build-photo-galleries?view=goldpicasa&album=6257870902911976177&userId=100048221976759975667)https://static1.pt-content.com/images/pt/2016/05/0031969camarorsssbigblocksilver_zpscpyhk-1.jpg
(http://s190.photobucket.com/user/l2azorback/media/003-1969-camaro-rs-ss-big-block-silver_zpscpyhkscj.jpg.html)https://static1.pt-content.com/images/pt/2016/05/0041969camarorsssbigblocksilver_zpstnky2-1.jpg (http://s190.photobucket.com/user/l2azorback/media/004-1969-camaro-rs-ss-big-block-silver_zpstnky26gj.jpg.html)
buildinusa
08-22-2016, 05:42 AM
Do you still have the moser rear end?
rocketrod
08-22-2016, 10:56 AM
What's the backspacing on the rims? Did you have any rubbing on the rear tires?
31069ss
08-22-2016, 05:02 PM
Where are you located ? Very interested in the wheels !
l2azorback
08-23-2016, 01:39 PM
All Parts $old Pending Funds.
