View Full Version : looking for info on mast motorsport ecu output
autoxtech
05-30-2016, 04:21 PM
please help , I have been trying to move the car , but I need the gauges to work, I have been working on this project for awhile now and have been in a road block for some time. I was wondering on the output page for the gauges what the setting for the coolant temp and oil pressure are. I might have moved or tried other setting trying to get the racepak working and now I'm just trying to get any guage working , I am hoping somebody with the mast motorport m90 ecu can look at there setting and help me out soon thanks,,
dontlifttoshift
06-02-2016, 08:50 AM
How is the racepak hooked up to the ECM? If you are trying to get that info through the OBDII port, it will not work as that information does not route through there with the mast ECM.
You will need to get with RacePak and see what they have for a CAN hook up.....J1939.
autoxtech
06-02-2016, 07:22 PM
i have tried the recap hookup with the can network and it will not work. the can network out of the ecu is j1939 and racepak does not support that, so i have moved on from that. i am trying to get just the oil pressure and coolant temp working just to move the car around and drive some before we start running it hard, but the output from the ecu is not working, i just confirmed with a voltmeter that i get no voltage out. but the ecu does have the right info and i confirmed that i have the right wires at the dash harness.
