dhutchison
05-30-2016, 02:17 PM
I may be "that Rookie" that may be posting this incorrectly, so my apologies in advance.
I have a 68 Camaro with a stock sub frame and control arms, but I did add a Flaming River bolt on rack and pinion kit. I am currently running 18x7 Foose Legend wheel with a 225 40R18 tire. It was my intent to drop the front of the car by 2". I initially tried drop spindles, but the inner fenders rested on the tire. So I went back to stock and changed to QA1 coil-overs to adjust the ride height. As near as I can tell the Foose wheels only come with a 4" back spacing. I would like to get the tire pulled in more into the wheel well so I can drop it some more. At the current height, the tire rubs the inner fender. I have read many forums on using the RideTech Tru Turn which allows me to run a 10" wheel with a 5.75" backspace. My car is not a corner carver, just a fun street machine that I take to drive to car shows and cruises.
So here is my challenge:
1) I would like to just buy a different set of wheels for the car and re-use my same tires, control arms, and power rack and pinion.
2) I don't want to pull the wheel in so far that it looks like a drag strip car
3) I need to figure out the right backspace to work with a 18x7 wheel so there is no chance of rubbing the sub frame when turned lock to lock
Any help would be greatly appreciated - Dave
