View Full Version : Widened Camaro front inner fenders available!
Ben@SpeedTech
05-23-2016, 10:47 AM
https://static1.pt-content.com/images/pt/2016/05/Extreme20wheel20tubs2082072_zpsba86mlgn-1.jpg
Hey All-
To go along with our new ExtReme front subframe we are now offering widened front inner fender wells to accommodate the wider 315mm tires and huge steering angle. These tubs have a lightweight and sturdy fiberglass construction and a semi gloss black gel coat finish. Check 'em out by Clicking here (http://www.speedtechperformance.com/index.cfm/page/ptype=product/product_id=508/category_id=23/mode=prod/prd508.htm)!
Fastlife831
05-29-2016, 08:15 AM
Can these be used with other manufacturers subframes or the stock subframes?
Ben@SpeedTech
05-31-2016, 06:56 AM
Thanks for asking. They were developed specifically for a Speedtech ExtReme frame, and are intended to accommodate 315 tires with 30+ deg of steering angle. With that in mind those are numbers you can't achieve on a stock subframe so the tubs would be no real advantage in that case. On aftermarket subframes it would be tough to make a tub that fits all since all frames are so different. They may possibly work on other subframes, but it would likely require some mods. They are made of fiberglass so that's not to say it's not doable. We have not tried them on other applications and have no real insight on what it would take to make it work. If anyone picks up a set and can take decent photos of how they made them work on a subframe other than the ExtReme frame we will be happy to share so that more people can take advantage of this great product.
