View Full Version : LQ4 Fuel Rail/Supply?
Tims 69
05-12-2016, 11:13 AM
I currently have a feed and return line. I'd like to know how I could use just a feed line with the vette fuel filter/regulator in it so I do not have to run 2 lines up front. I'd like to retain my factory intake and keep cost down. Is there a oem fuel rail setup that I could use?
Fuelie Nova
05-13-2016, 07:37 AM
What is the rest of your fuel system?
Tom
rallystyle
05-14-2016, 11:18 AM
i take it your using a stock truck intake. then it sounds like you have a 99-02 motor intake. find a 03-07 truck fuel rail and it is a feed only setup no return line.
Tims 69
05-14-2016, 11:50 AM
Yes I'm using a stock LQ4 truck intake and rail. I have a dorman truck style intake to clean up the look a little. If I use a newer rail will it bolt up to my intake? I want to keep the setup as clean as possible. Then do I use the vette fuel filter and just a short return hose back to the tank?
ProTour2V
05-17-2016, 11:25 AM
yes you can as long as the fuel rail has feed only. Some years have a feed and return.
