View Full Version : Stand alone LS1 Harness and PCM FS
1976CamaroGuy
05-03-2016, 04:42 AM
LS1 swap harness and flashed PCM For sale
This was in my personal car (1971 camaro) and I am very meticulous about stuff.
Harness is a stock 2004 Drive by cable with 24x crank. I modified it with mostly new wiring to so everything fell right in place and routed behind the intake through the firewall and PCM behind the dash.
But there is enough length that you can mount in engine bay too.
Comes with a current performance fuse box, that I wired with 3 relays for dual fans so they run in high and low speed like a LS1 Fbody.
PCM is a 2004 Express Van with a 5.3 stock tune using a LS1 intake and 28lb injectors. Emission and Vats turned off. If this isn't what you need you can have it re-flashed to your specs at lt1swap.com for $75
Comes with the harness, maf, and PCM. and the documentation I put together as well. All connectors and wiring are labeled too.
$425 + shipping for everything
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.15.11_zps2qxozrv4.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.15.16_zpsopqdoipz.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.15.20_zpsldsne6yz.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.15.25_zpsl2nqqsof.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.15.35_zpsr5utxr1t.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.15.41_zpsianbqkyu.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.15.46_zpsi4rzigc8.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.16.00_zpshuyydc4d.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.16.06_zpsoxln7z3h.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.16.45_zpsyaspwjqd.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.16.52_zpsybuzp9bx.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.16.58_zpsfuilnhby.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.18.43_zpspleobwvt.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.18.47_zpsdl7a2zul.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1310.photobucket.com/user/1971camaroguy/media/ls1%20harness/2016-05-03%2007.18.56_zpsaaxepv1e.jpg.html)
morris69
05-03-2016, 06:30 AM
I just pm you
1976CamaroGuy
05-03-2016, 06:33 AM
PM replied, thanks again
1976CamaroGuy
05-03-2016, 07:20 AM
sold to morris69 - thanks again
