View Full Version : AMC Hornet. Rear 17 or 18x9?
Nothingface5384
05-02-2016, 02:25 PM
The lil old 14s need replacement
I've already test fitted 245/45-17x8 4.5bs on the fronts
Not sure what tire and rim size to go on the back.
Looking at US Mags Bandits
Both 17x9 and 18x9 have 5.25 BS with +8offset
Tire sizes would be either
275/40-18 or 275/40-17
Now I test fitted some 255/60-15 on 15x8 4.5bs
Reason was they have the same thread width and section width as the 17 and 18 combo.. But they're taller at 27.1 vs 26.6/and 25.7 ..
They have plenty of room between rim and leaf spring..1in.
They physically clean quarter lip but with worn suspension it'll compress and hit lower section right above the rusty section of the lip where its bulged out...
Over 1/2 inch but less then 5/8in
Here's a pic of said 15 wheel which makes me believe both the 17 and the 18 would clear since they're both smaller in diameter
68Formula
05-02-2016, 02:53 PM
I'll just say, on the 1967/8 Camaro/Firebird, the wheel well opening is larger on the rear. So the 1" increase fills the well better, and makes it appear more symmetric. But I like to keep the rim diameters the same. So my personal preference is to stagger the tire, not the rim. The shorter sidewall on front should help the front grip, but the larger rear sidewall should help with the bite accelerating out of the corner.
I have 17s all around, with the typical 245/45 275/40 split. Eventually I hope to go to 245/40 275/40 split on 18s.
Good luck with the build. I've owned a couple AMC products in the past, so enjoy seeing them getting some love.
Nothingface5384
05-03-2016, 01:45 PM
Bump
APE
08-03-2016, 08:47 PM
I personally like stuffing the largest tire you can in there. The 18" may give you some more tire options, but the 17" will look great too. Cool build!
Hornet LSX
10-11-2016, 08:24 PM
17" up front and 18" out back. The look is balanced and fill the wheel wells nicely.
