View Full Version : Clutchless sequential shift for T56?
Badhand
05-02-2016, 01:20 AM
I've literally just started a pro-touring project, with a '69 Mustang body and brand new Coyote/T56 drivechain. I want clutchless sequential shifting and have heard about an Australian company called PFITZNER who do a kit for Corvettes...and now Ford.
Does anyone here have any experience of PFITZNER, their product, or recommendations for other companies who do similar kits to make this possible?
Craig@Bowler
05-02-2016, 07:50 AM
We built a T56 for a customer last fall using their gear kit. It was going behind a Ford 429 in a 69 Mustang. It is VERY nice stuff, and they price it accordingly. It does require extra machining to the transmission case so there's some extra work in setting it all up. Some of the guys who race in the n.a.s.a. series run these types of set up. I don't know of any other company that does a complete internal set up similar to the Pfitzner kit. There's a shifter only kit from S1 sequential to convert from your "H" pattern, but it is only a shifter that works with the existing T56 set up and is not clutchless, I'm not familiar with their kit but may be worth looking into if you aren't in need of a full out race prep gearbox.
andrewb70
05-02-2016, 09:46 AM
What you want isn't a simply having the right transmission. You need an engine management system and a shifter with a load cell. The load cell tells the ECU if there is an upshift or downshift that is about to occur. For upshifts the ECU will interrupt the ignition for a few milliseconds in order to take the load off the input shaft and thus facilitate the shift. For downshifts more advanced ECUs will also do RPM matching using a DBW throttle body.
I have a dog-ring T56 in my Cougar. It is built using the G-Force gear set. I don't have a sequential shifter, load cell, or ECU integration, but here is a video that will give you some idea of what you're in for...
http://www.youtube.com/watch?v=yB4Riqut-PA
MTI was working with PPG (same Australian company) on a complete setup, but I am not sure what happened to all that...
http://www.youtube.com/watch?v=XviGi4u0eTA
No matter how you slice it, you're looking at about $20-$25K to do what you want to do...
Badhand
05-02-2016, 11:51 AM
Thanks guys. Great to hear that the Pfitzner kit is quality. Still not 100% its what I'm after tbh. And thanks Andrewb70, but I'm after clutchless shifting as I've lost the use of my clutch foot in a motorcycle accident. Price is scary, but I'm building my dream car here. I don't want to cut corners or make compromises. However, the words 'load shifter' and ECU start to give me the jitters... as does $25K !
andrewb70
05-02-2016, 02:11 PM
Sorry to hear about your accident. As I said, clutchless shifting is complicated and the clutch still needs to be used for starts and stops. Might I suggest an automatic?
Modern automatics can shift very fast.
Badhand
05-02-2016, 07:46 PM
I can probably get away with the start stop, but not constant on track lifting etc. I still have the foot, but it and my knee have very limited movement.
Re auto, I drive an M235i Beemer 8 speed auto at moment and you're right, it shifts quick. Foot down and smash it through the gears. I guess, as I have the manual T56, I Just wanted something a bit more engaging and dare I say it, cool, than swapping it for an auto. Stick mounted, hand operated clutch, is another option, but the sequential quickness wins hands down.
TheJDMan
06-29-2016, 02:05 PM
You never stated if this car will be for street or track use.
Rod
06-30-2016, 08:58 AM
new one coming soon....simple set up
https://www.youtube.com/watch?v=gO-ScsLXPoE
http://www.s1sequential.com/
raustinss
06-30-2016, 03:18 PM
Price range ? .....strictly track use or could it work on the street too.... Or (in my Very limited knowledge) could you have the option of switching between the two
krom
07-04-2016, 08:08 AM
s1's website says $2650 aussi
raustinss
07-04-2016, 02:03 PM
am i missing it somewhere ....i dont see it when i click on t56 seq.
