View Full Version : Fat Bar Install Question for Rob
Tincup
04-27-2016, 07:45 AM
Hey Rob, I'm getting ready to weld my Fat bar in permanently, but I cannot find anything in the instructions on angle of the bars.
Should the bottom bar be;
( Looking From the side )
A: Parallel to the ground.
B: Parallel to the chassis.
C: Dosen't matter.
126573
Z06killinSBF
04-27-2016, 08:02 AM
Lower bars should be parallel to the ground at ride height. - Not Rob
RobNoLimit
04-27-2016, 08:14 AM
right you are. Thanks. The key there is to have the axle positioned at ride height. a slight up slope on the lower bar is OK, but we would like to see it within 5* of level. Also, "...parallel to the ground.. or .. chassis.. " I would suggest you set the chassis level when performing any chassis mods.
Tincup
04-27-2016, 11:53 AM
Thanks Rob, Just a little FYI , on Dodge trucks ( 61 to 71 ) the body and chassis are not parallel. I found this out the hard way.
