View Full Version : Everybody with turbo projects stop in and say hi
my72vette454
11-07-2005, 07:21 AM
I catch bits and pieces on here about peoples turbo projects and was wondering who all has a turbo project running or in the works? I would like to hear about everybodys setups, such as what components you are running for exhaust, intake, fuel systems, ect. Post up some pics if ya got em too. :icon996:
Mike
Tydriver
11-07-2005, 08:34 AM
Turbocharged LS6 into an AWD Typhoon
Pics at www.turbols6.com/gallery
shearer
11-07-2005, 09:40 AM
I have a few different projects gong on at once. Some various pics can be seen here... http://www.shearermotorsport.com/gallery/index.htm
My winter highlights if they all follow through are going to be a single turbo mod motor radial mustang, a 500in TT dart, and an ls1 camaro to prototype a turbo kit on. Hopefully it will be enough work to keep my mind off of the cold.
Nine Ball
11-07-2005, 12:53 PM
I'm building two vehicles this year.
twin-turbo 408ci LSX iron block for my drag car (1998 Pontiac Formula)
twin-turbo 348ci LS6 for my '69 Camaro convertible.
The drag car should be a high 8-second car (twin GT-40 turbos), the '69 will just be a fast street cruiser.
bigblockcapri
11-07-2005, 05:11 PM
my pickup 96 f150 300ci 6 turbo
my car 74 capri 5.4 DOHC twin turbo
shmoov69
11-07-2005, 08:07 PM
Mine is a 355 blow thru, Holley 650, Intercooled, twin t-3's, A-1000 pump, custom headers and stuff, Dynomax bullets.
:drive2:
TurboLark
11-08-2005, 09:04 AM
In the works :
1965 Buick Skylark- 383 SBC with TV81 turbo from a Detroit Diesel
will be making 1 3/4 mild steel headers that get coated
will try to work out a air-water intercooler first, but have the core for a air-air if needed. Tial 50mm blowoff and 44mm wastegate. All blowin into a 800cfm Holley carb. Shooting for 1000hp.
Martin71RS
11-08-2005, 01:09 PM
350 with blowthrough turbo in progress....(slow progress I might add) aiming for a conservative 400HP
see my page for more details:
www.pro-touring.nl
Martin
texlurch
11-09-2005, 05:43 PM
Mine is a 68 Camaro with twin turbos and twin intercoolers, on a 96LT1.
All homebuilt with JY parts.. turbos off a GM diesel, Saab intercoolers, modified S-10 headers..
7 psi on the stock LT1 did 405 RWHP/513RWTQ, so it works fine. I am selling the 68 and putting the drivetrain in my 70, so that will be for the future.
Fuel system is Aeromotive A1000 and reg;, Accell DFI and MSD handle the ignition
Y-TRY
11-10-2005, 07:03 AM
"Hi". My car is a '68 Camaro with twin turbo MoTown block 6" rod, solid roller 406 stroker with twin PT-52 turbos, HKS Wastegates, CarbShop blow-through, HKS SSQV BOV, etc. Aeromotive A1000 and regulator. The headers are from Kooks, but were modded to fit, I designed all the rest while my cousin at LG Motorsports welded all the tubing together. 720rwhp at 6psi. Normal boost is 9.7 so go figure. Glad to meet you guys.
my72vette454
11-11-2005, 06:41 PM
Looks like there is some pretty cool turbo setups out there. My twin turbo setup is the first experience I have had with forced induction and DAMN its pretty cool! O and by the way I am running a 486 bbc with twin rajay 301e's with .8 a/r exh housings, aeromotive a1000 pump with a 13204 reg, holley 750 carb, 38 mm tial wastegates and a tial 50 mm bov. To those of you that are still building, let me warn you that it will be hard to wipe the smile off your face the first time you go for a test drive. Thanks for the posts guys, its nice to see other's setups!
Mike
LS1NOVA
11-11-2005, 08:27 PM
In the works when money allows:
71 Nova, DSE tubs, cage, etc.
370" Gen 3 based off 6.0 block, stock except for forged pistons, rods, LS6 cam and valvetrain.
GT-45 Master Power single
DIY piping
Treadstone vertical intercooler
exhaust manifolds from a 05 GXP 5.3 (damn budget)
Looking to make 500 RWHP initially then turn it up. :drive1:
viper11
11-12-2005, 02:20 PM
in the works
74 dodge charger 440(fully modified and daily driven)
adding twin turbo's with a cutler/holley mpfi (modified), 2 x t61's, intercooled with new wheels/tires and 4wheel disks to complete the upgrade
Chuck
11-12-2005, 09:46 PM
I have a Buick Grand National transplant in my 69. Have a TE-45A turbo, 80# injectors and a front mount intercooler. Hard to fit it all in but worth the trouble. Best ET to date is 10.83
Y-TRY
11-14-2005, 11:53 AM
Mike
Hey Mike- I have the same fuel pump and regulator and am having an issue:
The fuel pressure is increasing almost proportionatley with engine rpm. All the electrical checks out, and the problem stops with the boost-reference disconnected. So under nomral load and acceleration the fuel pressure increases to the point of flooding over the needle/seats and thus the engine. It's like the regulator is increasing pressure even when the car is not in boost.
Have you (or any one else) encountered this?
shmoov69
11-14-2005, 08:01 PM
What return line are you running? I had a too small return and had an issue similar to this. Also remember, even though the boost gauge is not showing "boost", it still has positive pressure and may be opening the reg just a little and the return may not be big enough to send it back to the tank. I got a 1/2" aluminum return on mine and it actually is not big enough, but will do. I just need to get the good regulator, I got a small Mallory on it and it is NOT near big enough.
Y-TRY
11-14-2005, 08:18 PM
I'm running -10 feed and -8 return lines. I'm leaning toward blaming the reg. since the problem doesn't happen with the line removed. I just can't get on the throttle without the line hooked up.
Maybe the reg. sees any drop in vac. as boost? If I find anything out from Aeromotive I'll post here, too.
my72vette454
11-15-2005, 08:15 AM
I used 5/8 line on mine for both the supply and return, seems like I remember someone on another board with a similar problem bacause of a too small return line. Also I have my boost reference line coming off the intake pipe just before the carb hat so I dont have any vacuum going to the regulator. If your problem goes away with the line disconnected, you might try plumbing your boost reference line before the carb and see what happens. I have heard there is a pressure drop of a lb or 2 because of the carb and I thought it would be better to sense boost pressure before the carb than after to help insure the fuel pressure rises high enough to supply the carb properly. Going lean under boosts not a good thing. Hope this helps.
Mike
andrewb70
11-15-2005, 08:25 AM
Welcome Chuck. Where are you from?
CAMAROBOY69
11-15-2005, 08:44 AM
Now that sounds like a really fun project. 10.83 :cool:
Y-TRY
11-15-2005, 05:00 PM
Mike
Hmm. Got me thinking: I have my boost refrence tied in at the hat. There is a "T" from the hat and the other side of the "T" goes to the line running from the baseplate, which I believe pulls vacuum much of the time. Makes me wonder if the vac. from this line is sending weird signals to the regulator. So the reg is almost actually reading from the baseplate instead. Hmmmmmm.
Twin_Turbo
11-16-2005, 04:11 AM
hi :) just a 355 TT w/ 4 dellortos..soon to be replaced by a 598 that someday may receive 2 turbos also.
kmcanally
11-16-2005, 04:55 AM
I love this thread...no turbo...not yet anyways.
BMF Machine
11-16-2005, 02:36 PM
Shaun would probably like his car in this thread! He has had some troubles posting, so here they are! Wow! What a ride!:eek:
GRASSHOPPER
11-16-2005, 04:30 PM
HEY HEY ITS THE GRASSHOPPER..... Well my Winter Project is goin to be my 1964 chevy Nova that i just bought for $5.000 from a Customer at my work he has lost intrest in t so its my now. Its has full Heidt's Front end on it Currie 9 inch rear end New Metal all the way around the car from hood fenders to doors and guarter panels ill be painting in very soon. Im installing my Chevy 350 with a single turbo set up i bought from my boss along with a 400 turbo trans. Should be fun in the spring when it hits the streets...........:firefire: :firefire: :firefire:
my72vette454
11-17-2005, 09:39 AM
Hey this thread gets better by the day! Nice rides guys!! So whats Shaun's nickname on here?
Travis B
11-17-2005, 09:56 AM
TwinSting......
www.evodindustries.com
shmoov69
11-17-2005, 04:57 PM
If it doesn't happen when the boost refrence line is not hooked up, then I can almost assure you that the return line is too small or the regulator spring cannot overcome the pressure from the pump once it starts to raise. With forced induction, it can still see small amounts of positive pressure and still not show as boost. Kinda like the boost has to overcome the vacum before it shows as boost.
Let us know!
jdpepper
11-17-2005, 05:17 PM
406 sbc w/ twin t-61's, almost done w/ cold side then off to my fabricator for the down pipe & exhaust...then I'll be able to remove it all and have it coated
viper11
11-17-2005, 05:59 PM
more pics jdpepper
your setup uses similar turbo's as mine
do you have more info on your setup... what size bov's, wastegates, piping did you use??
what hp and tq you lookin for
jason
jdpepper
11-17-2005, 07:50 PM
more pics jdpepper
jason
I'll have more pics when I get the dp and exhaust on. I'll be using a 50mm Tial bov and two 35mm Tial wg's. As far as cold side piping I'm using 2" from turbo to IC and 3" from IC to carb. The hot side will be dual 3" all the way out the back.
The engine
406 cid
dart little m
eagle crank, rods
je pistons (8.2)
cammotions tight lash roller
afr 210's
victor jr intake
csu 750 carb
Hopefully get 1000 + to the wheels
Y-TRY
11-18-2005, 10:28 AM
Looks good, JDPepper! Cool to see how everyone is accomplishing this!
It looks like you're going with a lift-off hood. which one? Would love to see the rest of the car! Very similar powerplant to mine. It's gonna take some mean boost to get us over 1000hp, but we can do it!
killer69
11-18-2005, 08:36 PM
We are doing a 66 Beaumont heres the specs
502 with 2 gt70 turbos
world block, AFR 345 cnc heads, Hogans Intake, Burns 321 stainless headers, Spearco intercooler, callais forged crank , manley rods , cam motion solid roller, comp belt drive mcleod dual disk clutch, Jerrico 5 speed road race Magnesum case trans, Motec digital fuel injection with traction control, Aeromotive dual pumps with digital controler -12 supply. should be able to make 1500 hp at about 15psi boost
esenior
11-20-2005, 11:46 AM
Not sure if this would help, but I was talking to Aeromotive last week about their Fuel Pump Speed Controller (http://216.242.145.16/products/product.phtml?p=31). They explained that you do not want a large volume of fuel circulating through the system since the fuel carries heat from the engine back to the tank. Not sure how true this is, but it liked the idea of controlling the fuel volume based on RPM's. This should also help fix any problems due to too small of a return line.
Let me know if anyone is using one of these since I'm planning on ordering one.
My car is a 69 Camaro Convertible, ZZ502, Whipple EFI Supercharger, and Aeromotive's pump/filters.
---Eric
Y-TRY
11-21-2005, 05:53 PM
Those controllers are cool.
I'd suspect the return line issue except that the problem stops when the boost-reference is bypassed. I'm convinced the regulator is increasing pressure based on faulty info. There is either something going on in the hat or that "T" with the baseplate is somehow screwing it all up. I'm going to stop Ninja-ing this thread and move this to another thread....
1984 camaro
12-04-2005, 12:58 PM
about air coolers i had to heavily modify the front of my camaro talk about no room trying to stuff a radaitor thats 4 times thicker a/c unit and a air cooler it fits but took several weeks of head scratching and probley about two days of fab work go figure but its well worth the time fuel system has two a-1000 pumps one on speed controler and other manual switch
calereeves
12-09-2005, 12:20 PM
I've been a member of this board for a while, but I haven't stopped by in months. I've got a 78 Trans Am thats getting a 540 with twins. I've got the headers fabbed up, they're at a welder's getting TIGed right now. I can't tig for anything, much less something that has to withstand the stresses of a turbo motor.
I sold the motor thats in the second pic, so I used a dummy block and head to fab the passenger side (first pic).
shearer
12-09-2005, 04:41 PM
what the heck happened to your turbo?
derekf
12-09-2005, 05:35 PM
I like the turbo - is that floral foam?
vintageracer
12-10-2005, 07:09 AM
Does a 87 Grand National count since it came with a factory turbo? I just bought one this week. They can go very fast in the quarter however I plan to work more on the suspension for ride and cornering.
syborg tt
12-10-2005, 08:23 PM
Building a tt Aluminum V6
calereeves
12-10-2005, 08:41 PM
Bingo!:yeah: Got it at Wal-Mart, used Innovative's dimensions, and about 3 hours of work with a pocket knife later I had a full scale innovative GT series turbo. It is even 360* clockable due to a pencil epoxied in as an axis! (I live in a dorm and I get bored sometimes...) I'd suggest anyone that is building a turbo setup use something of the like to mock everything up.
Colin Frolick
12-25-2005, 04:00 PM
I'm going to turbo my 1970 Imperial. The garage is full though so it may be awhile.
80superbu
01-22-2006, 07:59 PM
Ok, my first post here. My car is a 1980 Malibu, LS1, FAST 90 intake Nick Williams 90mm TB, GT42 turbo, 9" rear and a few other things. I'm still geting other pieces together..BOV, wastegate, piping and maybe some AFR heads. Not sure I'm gonna be happy with the stockers.
Only have pics of the car still on the trailer
Hoping to have in readyby summer. I'm leaving for 6 weeks in a month for more military schooling but at least I miss out on the winter here in the mountains
nitrorocket
01-23-2006, 04:13 PM
I have a Twin Turbo LS1 Chevelle!
https://static1.pt-content.com/images/pt/2006/01/_DSC0004-1.jpg
Y-TRY
01-23-2006, 04:21 PM
Coolness
syborg tt
01-23-2006, 06:01 PM
yep that is really nice - almost makes me wish i had a v8.
okay i lied it does make me wish i had a v8
anychance you can show more pics or a link to your pics
nitrorocket
01-23-2006, 06:50 PM
Here are some more pics of my build.
https://static1.pt-content.com/images/pt/2006/01/DVC00733-1.jpg
https://static1.pt-content.com/images/pt/2006/01/DVC00894-1.jpg
https://static1.pt-content.com/images/pt/2006/01/DVC00874-1.jpg
https://static1.pt-content.com/images/pt/2006/01/DVC00800-1.jpg
https://static1.pt-content.com/images/pt/2006/01/DVC00783-1.jpg
https://static1.pt-content.com/images/pt/2006/01/DVC00780-1.jpg
https://static1.pt-content.com/images/pt/2006/01/DVC00778-1.jpg
syborg tt
01-23-2006, 07:02 PM
looks like you need a page of your own for the build of this beast
nitrorocket
01-23-2006, 07:05 PM
You would not believe how cheap I built this "Beast". Most people could'nt even guess.
jdpepper
01-23-2006, 07:55 PM
:headbang:thats kickass, what a beautiful car:twothumbs
shmoov69
01-28-2006, 08:46 PM
VEEERRRRY nice! Times?
nitrorocket
01-31-2006, 08:14 PM
Time? I blew my converter at half track, but it still went 10.50 @ 137 mph on 93 octane and street tires!
shmoov69
01-31-2006, 08:31 PM
Sweeeet!!
slow4dr
02-02-2006, 12:06 PM
I am working on a 63 Nova that has kinda received the nickname "blasphemy". It will be powered by a 2JZGTE and a big single. It is mainly set up to go straight but it will spend time on the street. I have never really cared for show cars so I won't spend much if any time making the car look good. Maybe some primer and the basics just so it isn't an eyesore. It is far from being finished but here are some current pics.
shmoov69
02-02-2006, 06:50 PM
Gonna win some money eh? Nice! I am assuming a more door.
slow4dr
02-02-2006, 07:24 PM
I guess the screen name is misleading. :pat: I actually made that name when I had my Galant VR4 and I just kept it when I got my SRT4.
The Nova is a postless 2 door.
jdpepper
02-02-2006, 09:58 PM
Thats freakin kick ass man:headbang: keep us updated...
worldbob
02-03-2006, 08:16 AM
I'm working on a 66 Impala convertible. Big Block with twin 62-1s. Setting up the suspension (hotchkis) and trans (4L80E) then I'll work on the underhood fab.
gEtyOpAPiOn
02-08-2006, 02:14 PM
kinda late but im in the club now !!! twin turbos here i come!!
nitrorocket
02-08-2006, 05:55 PM
Did you just get some turbos or what??? What kind??
gEtyOpAPiOn
02-08-2006, 06:19 PM
I got some precision 60-1 from your friend hehe
nitrorocket
02-08-2006, 06:32 PM
That is too funny! That is why I asked. I actually met him through selling a motor, and I ended up helping him a little with his car.
He said he sold them to a guy with a '69.
gEtyOpAPiOn
02-09-2006, 12:18 AM
yep that would be me ...im sorry my pms were full ....
Monty
03-19-2006, 05:58 AM
I'm in the process of building a twin turbo LS7X, using the 9.800" deck, 4.125" bore Warhawk LS7X block from World, along with a pair of their 12* CNC LS7X heads. I'm thinking of using a pair of T70's. It's going in a 1972 Corvette Convertible
I built a twin turbo SBC 427 about 4 years ago that made 1200hp/1000tq on pump gas. It was installed in a 1982 Corvette but I sold the car a couple of years ago (regrettably).
http://www.twinturbocorvettes.com
myclone
03-19-2006, 07:14 PM
There is NO way Id want to change plugs in that thing!
Im just giving you grief as it looks to be a REALLY nice set up you have there :) .
shmoov69
03-19-2006, 08:54 PM
Monty, I have drooled over your vette pics many times! AWESOME!!:drool:
Monty
03-20-2006, 12:09 PM
It's alot easier to change the plugs from underneath...plenty of room.
my72vette454
03-20-2006, 04:46 PM
Hey Monty, how is the vette coming along? Cant wait to see the finshed product! This has been a fun post to follow as there are lots of turbo projects listed in here, keep em coming.
Mike
myclone
03-21-2006, 05:08 AM
I figured as much since I have to go through the fender well openings to get to mine (too much driveline underneath to get to em from the bottom).
Very nice set up you have there none the less :hail:
80superbu
04-12-2006, 06:18 PM
I'm still piecing together parts. Have decided to go ahead and put in some forged pistons instead of the stockers and get my compression down to 8.5 maybe 8.75:1. Then get my fuel system parts and start putting it all together.
Slow but sure
Twin_Turbo
04-13-2006, 05:08 AM
I never posted pics of my lowly 355 TT...still not ready, need to finish the intercooler piping and placement but I have too much other stuff still to do.
https://static1.pt-content.com/images/pt/2006/03/top1-1.jpg
80superbu
04-13-2006, 03:09 PM
Ummm..what kind of car is that going to be :dunno:
gen3bu
04-13-2006, 07:26 PM
1993 sonoma twin tbi single turbo (cheap homemade turbo kit)
1991 crx si (cheap homemade turbo kit)
1979 malibu LS1 with twin remote mounts
1995 beretta 2.2 t3/4 hybrid (cheap hmt kit for a dd)
is it obvious that i like boost
Twin_Turbo
04-13-2006, 11:02 PM
A 1982 Corvette....
https://static1.pt-content.com/images/pt/2006/04/flares1-1.jpg
https://static1.pt-content.com/images/pt/2006/03/fronton-1.jpg
Z06killinSBF
04-14-2006, 03:05 AM
I didnt read the whole thing but how many people are running non-intercooled set-ups and how much boost are you running? What is the limit to need an intercooler?
slow4dr
04-14-2006, 06:34 AM
There are a lot of factors that could change this including but not limited to compression, compressor map, back pressure, fuel octane and your tune.
We were able to make around 650 HP non intercooled with a 366" SBC with 8.4:1 compression, 2 60-1 turbos, and crappy California 91 octane with 7-8 psi. We put 100 octane VP in the same motor and turned the boost up to 11-12 psi and made a little over 800. The intake temps were nearing triple ambient so you would have to be very careful with the "tune" and run the knock sensor settings very sensitive.
350SS
04-20-2006, 06:05 PM
Here's my piece of junk....
https://static1.pt-content.com/images/pt/2006/04/th_100_5686-1.jpghttps://static1.pt-content.com/images/pt/2006/04/th_100_5679-1.jpg (http://s37.photobucket.com/albums/e56/350ss/?action=view¤t=100_5679.jpg)
https://www.pro-touring.com/forum/showthread.php?t=17651
viper11
04-23-2006, 07:13 PM
ok
finally got the turbos mounted to the hotside, now i've got to try to mount the wastegates but dont seem to have any room left, other than cutting the inner fenders and mounting them through them ! (any suggestions?)
i've also got to fit the oilpan with bungs/fitting for oil drainback and fab the coldside, wire the fuel injection and replace the rearend and it should be fire up time
heres some pics
jason
twoduners11
04-26-2006, 11:37 PM
heres some
TT331FB
05-05-2006, 09:31 AM
Not much room in a vintage Mustang. I made 454RWHP, 510Ft-Lbs at 10 PSI.
Eric
jdpepper
05-05-2006, 08:37 PM
Eric
very nice:cool:
Kenova
05-07-2006, 10:53 AM
Eric
Damn, that is tight. Talk about putting 10lbs. of "stuff" into a 5lb. bag!
Ken
TT331FB
05-07-2006, 06:30 PM
Ken
LOL You are the first fellow to use that favorite saying of mine. I suppose I coud have taken the shock towers out but then in wouldn't be a Mustang anymore, IMHO.
Eric
Andrew F
07-08-2006, 09:39 AM
https://static1.pt-content.com/images/pt/2006/07/287498-1.jpg
https://static1.pt-content.com/images/pt/2006/07/287495-1.jpg
https://static1.pt-content.com/images/pt/2006/07/286078-1.jpg
https://static1.pt-content.com/images/pt/2006/07/271042-1.jpg
https://static1.pt-content.com/images/pt/2006/07/271037-1.jpg
best ET 10.46 133 best mph, more left in it.
amxman
07-10-2006, 11:19 AM
In progress, 1964 Tempest 4 door, 215 six with 12 lbs of boost, fuel injected. backing it up with a 2004R
Already done:
tall spindle 12 inch brake swap
16x8 wheels
Eibach springs
BB_Mike
03-23-2008, 09:04 PM
Thought I would bring this thread back from the dead.
I am in the research phase of my Twin Turbo 1971 Chevelle. It will be a big block motor, around 500cid. Looking for a modest 1000HP. More can be had, but this will be a street/strip car on a 10" wide tire. Using the power is for later. The car is undergoing a frame off resto and I'm doing all of the work. Hope to have it all done spring of next year. The car made 450HP and ~480TQ with a 414cid big block. So I figured I needed to double that. Which means I should be running ORSCA in 3 years, right? I try to race in a straight line, but this build will be more about corneing than sixty footing.
badbu68
03-24-2008, 12:26 AM
Spelling was never your strong suit Mike. Sounds like a lotta fun but if I was you I'd look into a lsx if you're planning on cornering.
BB_Mike
03-24-2008, 06:56 AM
Yeap, I will continue to suck at the spell check.
By cornering I don't mean a canyon carving road racing machine, I just mean it will be able to hold its own and be much better than stock. i.e. no ladder bars out back and toothpick front control arms.
syborg tt
03-24-2008, 10:27 AM
someone need to post pics of that awesome TT lsx Chevelle that was 4-sale on the BB
okay here is the link
https://www.pro-touring.com/forum/showthread.php?t=37045
BB_Mike
03-24-2008, 07:20 PM
I do like the way Scott did his plumbing on the hot side. But I want the turbo's facing out. He just dropped off of planet earth after he sold it.
I will keep my brake booster, and I would like hydroboost. But that probably can't happend unless I go single turbo. The hot side piping for that is utter nonsense!
badbu68
03-24-2008, 07:30 PM
I hear ya Mike. Are you planning on going efi? It'd be cool to do that with e85 if that's easily available in your neck of the woods. Living in a corn state makes that easier for me, but I'd like to stay n/a and just use a ton of compression.
edl406
03-25-2008, 03:02 PM
https://static1.pt-content.com/images/pt/2008/03/s10new015-1.jpg
406 sbc, edelbrock 1000 cfm intake, twin turbo's.....
https://static1.pt-content.com/images/pt/2008/03/updateturbos006-1.jpg
and a 6 speed t-56 viper trans...
still working on it, Trying to figure out some tuning and finish some odds and ends.
Cant wait for summer!
Morgan
03-27-2008, 09:12 AM
Do factory turbo projects count?
shmoov69
03-27-2008, 11:59 AM
That don't look like a factory turbo to me! What is it?
showme
03-27-2008, 02:26 PM
Hammerhead is in the process of getting twin turbos,but my pic's are too dark to show!
https://static1.pt-content.com/images/pt/2007/10/ESCW_2007_776-1.jpg
https://static1.pt-content.com/images/pt/2008/03/turbo5-1.jpg
This is just a pic of the "mock up",nothing is cut to fit or in place yet.
https://static1.pt-content.com/images/pt/2008/03/PHOT0026-1.jpg
Morgan
03-28-2008, 04:07 AM
Very true, the turbo isn't the one that came on it stock. What I meant is that the truck came stock with a turbo. The upgraded one on it is a PTE 44.
shmoov69
03-28-2008, 06:27 AM
I know what you ment, just wanted to know about the turbo! LOL Any power levels? 1/4 times? With that setup that is.
Morgan
03-28-2008, 06:31 AM
No stats yet. I am in the process of installing a methanol injection kit and keep debating on a BS3 computer w/ wideband. Once I have some I'll post.
BB_Mike
03-28-2008, 02:35 PM
I would like to go with a blow through carb for nastalgia and asthetics, but EFI affords me better tunability for different fuel grades (i.e. E85 or even 100+ octane). EFI will also allow me to get better MPG. I plan to to drive the car a lot. Big Stuff 3 is appealing, but not cheap. I also plan to go with an electronic boost controll. Heck, I'll have $3k in software alone! pfft. Maybe I should build my own boost controler? Hmm, there's an idea.
ZZ4Blazer
03-28-2008, 10:18 PM
Mine so far. Hopefully running this spring.
edl406
03-29-2008, 08:21 AM
I like it.
How big is the downpipe going to be and is it going to fit between the frame and engine?
CARB and turbo? I dont see an efi setup.
I see you have a 6 speed, same here. Isnt that the best thing since sliced bread :yum: !!!!
ZZ4Blazer
03-29-2008, 02:01 PM
Downpipe will be 4" till about halfway behind the bed, then split into dual 3" mufflers before the axle. Its mocked up somewhat decent, but I still need to make or get a 3.5-4" pipe to connect to the turbo.
Yes, it will be carbed. Will be running a 750 holley from CSU. Have heard nothing but great things about them, even great driveability. Thats my NA motor pictured still, I have a stock bottom end 350 that will be going in there in a few weeks. Waiting for my cam to come, and need to get my heads done. Hopefully the motor will hold for a bit, and if not, doesnt take out the cam, heads, new oil pan, etc.
I love my truck being stick. I love banging those gears. Love downshifting into a corner, blowing through at scary speed in a truck, powering through and banging the next one.
Im not fan of white, but Im digging your first gen. Very clean. I love them, but standard cab is just too small for me. Hows the body line filled? Welded or glassed?
edl406
03-29-2008, 10:41 PM
The line is glassed, I did it over 10 years ago and still holdin in there, no cracks.
Yeah, Im not so fond of white anymore, thinking about black But I know im in for some work getting it straight enough for that. I may go red , I dont know. After I get the twin turbo stuff done Ill worry about the color.
I like the reg cab, less weight.
I hope the carb thing goes well for you, several guys talked me out of it, thats why im running efi.
I did see a couple of dyno pulls on you tube with carbs, you might want to go on there and see who the company was that was building them.
ZZ4Blazer
03-30-2008, 12:14 AM
I've done some research off and on about using the carb. I've probably read for hours on theturboforum.com about carbed set ups. CSU guys seem to know what they're doing. Almost down to plug and play tuning over the phone. Lots of guys claim that even the jetting is almost dead on right out of the box.
Dont get me wrong, I'll eventually swap to an efi set up, primarily for better driveability, and better fuel control in hard corners. Im already having problems keeping it from dumping fuel during braking or a hard corner. And I dont push it to the point on the street, and Im still on street tires. Im sure it would be worse on a track with some decent rubber.
I sat down tonight, and I think I might have to wait till next year for the turbo. I just dont think I'll have the money for everything. I can either
A: put it back the way it was, work my nitrous out better and drive the balls off it this year.
B: let it sit till I have the cash for everything.
I think Im gonna spend 1/4 of the money I was gonna, on upgrading a few things and have it back running again as soon as the weather is decent enough. I wanted to upgrade the front wheels with wider rubber, add the matching C6 brakes to the rear, and add a ps and oil cooler to it.
Kiddi
03-30-2008, 11:28 AM
Here's my turbo project.. 1969 GTO clone with stroked 400 engine and T88 single turbo all stainless piping..
The pics are old... It will be finished next month!
BB_Mike
04-01-2008, 12:26 PM
I'd love to see those pics Kiddi. Your engine bay isn't too different than my 71 chevelle.
z28orshoot
04-01-2008, 10:17 PM
496, twin master power 70mm, 60mm wastegates, not as nice as some but gets the job done. i will eventually make some stainless headers of it when time and funds allow. under the stock hood for the win.
https://static1.pt-content.com/images/noimg.gif (http://img253.imageshack.us/my.php?image=dsc00210uz6.jpg)
tb8125
05-01-2008, 05:27 PM
my gn
Larry Callahan
05-17-2008, 09:40 AM
Any of you running a hyd roller lifter with your turbo motors? I am trying to decide on a cam. I am running Trick Flow heads and an old school 70's 350 block with a stroker crank to make it a 383
4kops
05-29-2008, 01:32 PM
Well very new to this forum building a 57 chevy 2dr post car with a Art Morrison chassis witha Steve Morris Racing Engines 572 bbc with twin F1 mdframe Turbonetics ball bearing turbos. Hoping for around 1600hp on pump gas. Also doing a 62 Bubbletop with a 572 620hp crate motor. Bubbletop is almost done and the 57 should ce done late in the year or first of next year
shmoov69
05-29-2008, 07:50 PM
Nice!! Good to have you! Buuuut......
:postpics:
scotzilla
06-05-2008, 12:38 PM
https://static1.pt-content.com/images/noimg.gif (http://s36.photobucket.com/albums/e42/scotzilla/?action=view¤t=insectwihahairdryer.flv)
CptKlutz
06-05-2008, 02:09 PM
Just started on my 69 Mustang, see project post here.
https://www.pro-touring.com/forum/showthread.php?t=43846
The short version:
302 based smallblock: 363 stroker on DART block, all forged & roller, Arias pistons, 0 balance, T-76 turbo, I/C, BigStuff 3 ECU and BBK SSI-R injection.
Chewy72ss
06-05-2008, 04:47 PM
Lot's of sweet setups. My Wagon will be getting twin T61's to feed the 355 through an HSR intake. This will hopefully commence soon after the rack and pinion is setup, and the 3-link rear is complete.
Some info:
.030 over "010" 350 block (355ci)
Forged pistons, rods, and crank.
~9.0:1 Compression ratio
224/224 .488/.488 114lsa cam
Holley Stealth Ram
Syclone ECM
40ish# injectors
Innovate WB02
Twin T61 turbos, w/ antisurge housings, .96 A/R
3" DPs into oval exhaust, dumped Super 44's
slow4dr
06-18-2008, 12:48 PM
:cheers:
https://static1.pt-content.com/images/pt/2008/06/0134064R103717-1.jpg
https://static1.pt-content.com/images/pt/2008/06/0134064R103315-1.jpg
https://static1.pt-content.com/images/pt/2008/06/0134064R103114-1.jpg
https://static1.pt-content.com/images/pt/2008/06/0134064R102913-1.jpg
https://static1.pt-content.com/images/pt/2008/06/0134064R103516-1.jpg
flynbrian
07-03-2008, 08:35 AM
This is my first post here, I have a 1974 Chevy Monte Carlo with a 67mm Garrett turbo and blo-thru carb set-up. I built the driveline last year and in process of body and paint now.
I have about 540 Horsepower and the car has only been test driven a few times. Mechanical racepump fuel pump and Aeromotive boost ref. reg. with -8 fuel lines too & from the tank. 575 cfm BG Mighty Demon Blo-Thru Stock HEI with weights pulled and welded, 22 degree's timing.
50mm Tial BOV and 38mm Tial Wastegate. Stock Exhaust manifolds with passenger side flipped. I bought the Turbo used from a Kid who had it on a Honda Del-Sol...The bearings were shot and the car could hardly make boost cause the turbo was too big for it.
I paid $400 for the $1300 Turbo and rebuilt it myself. I pulled the motor and put new bearings and Oil pump in it and a new double roller timing chain while putting a drain in the pan.
I run a -4 supply hose and a -10 drain to the pan. No Intercooler yet But I do plan to add water/meth injection soon.
I use a NGK Airdex wideband.
I also have a 69' Pontiac Firebird that someday I want to turbo...I bought a Precision 76mm for it and a set of H-beam rods..The motor is already built N/A for now with Edelbrock RPM Alum. heads and Comp Valvetrain and 775 CFM Annular DP Carb. MSD ignition and a handful of other goodies...It has a Supercase Muncie 4 speed and a built rearend too.
The Monte Carlo is going to be out prowling by the end of this summer and the Firebird is at least 1-2 years off from now.
TT402LS1
08-03-2008, 09:42 AM
Hi!
Ron
ssrogers
08-03-2008, 04:29 PM
1980 Camaro, 355, 4 spd, single turbo, just going for 400hp.
No where near close enough for pictures.
705.0Merc
08-04-2008, 09:35 PM
The turbo is the best thing I have done to my car.
old 5.0 motor
single t-70 Master Power turbo 9psi
Carbureted Holley 600dp
Ebay 40mm wastegate
bosch bypass valve for now
DIY kit 1 1/2" primary shorty headers, 2 1/2" crossover, 3" down pipe split to dual 2 1/2" out the back, no mufflers.
3" intake pipe to 24"x12"x3" intercooler
jonfarrugia
02-26-2009, 04:56 PM
1967 Beaumont with a Twin Turbo Viper power train. 1000RWHP!
https://static1.pt-content.com/images/pt/2009/02/DSCF3832-1.jpg
Chewy72ss
02-28-2009, 08:56 PM
Here's my wagon so far... Hopin' to get around 700hp to the ground. We'll see.
https://static1.pt-content.com/images/pt/2009/03/DSCF17311-1.jpg
icebird84
02-28-2009, 09:22 PM
I like to see more from this build
camcojb
03-01-2009, 08:36 AM
that looks great, very good job!
Jody
Ratty 46
03-01-2009, 06:38 PM
I'm working the chassis right now ....... 4 link FAB9 coil-over rear & tube A-arm coils up front on my 46 ford coupe and the power will come from a SBC with a single intercooled 68mm turbo. A 5 speed will shift this ride into funsville.
Alston/Chassis Works is providing the chassis parts & hopefully I'll have it off the jig late summer & the intercooler mounting & headers can be built.
Time & money.
I wish I could afford the twin set up.
Ratty 46
Bruning Auto Design
03-01-2009, 07:21 PM
twin turbo new gen 426 CID Hemi stroker
https://static1.pt-content.com/images/pt/2009/02/_DSC5481-1.jpg
https://static1.pt-content.com/images/pt/2009/02/_DSC5484-1.jpg
on display at SEMA 2008
more pics and specs at www.etikitchallenger.com (http://www.etikitchallenger.com)
Chewy72ss
03-01-2009, 07:32 PM
Way to own the page T.J.
Very nice.
Chewy72ss
03-04-2009, 07:04 PM
It feels like I'm taking over this thread, but I gotta have an up-to-date picture!!!
https://static1.pt-content.com/images/pt/2009/03/DSCF1812-1.jpg
protour_chevelle
03-05-2009, 03:24 PM
Nothing nearly as fancy as the above, but done in my garage -25 celcius, no heater,... lots of fun.
https://static1.pt-content.com/images/pt/2009/03/000_0152-1.jpg
https://static1.pt-content.com/images/pt/2009/03/000_0154-1.jpg
https://static1.pt-content.com/images/pt/2009/03/000_0298-1.jpg
https://static1.pt-content.com/images/pt/2009/03/100_0669-1.jpg
darthvegagt
03-18-2009, 01:34 PM
Hey everyone,
First off I'd like to say great job on the turbo specs and pictures of your projects. They're all awesome!
I have a 69 camaro BB454/TH400 like my signature says. I have always wanted to build a twin turbo car and hopefully one day will be able to. I am on a budget with my whole build so I can never afford a dart block, expensive fuel injection setups and all the expensive parts to build one (even though I wish I could:doh:). But I have seen different companies selling TT kits for SBC on EBAY and other places for relatively cheap (some complete kits as low as $750.00). What do you guys think of these kits?
I was thinking of eventually buying one and making/buying some BBC turbo headers and just using most of the other stuff that comes with the small block kit to adapt it to my Big block. This is something I feel comfortable in doing fabrication wise and its something I could realistically afford. I realize of course I will need to build the motor I have to handle twin turbos and would do defiantely that. I'd just like some input from you all that have built TT motors and what you think of my idea.
I'm not looking for a race car just a unique TT big block car that I built myself. I know buying a supercharger and bolting in on is the easy alternative but thats not what I'm looking for. THANKS FOR ALL YOUR HELP GUYS!
buds87gn
03-28-2009, 11:26 AM
This is my 87 GN. Picture is a couple years old, the car has full interior a/c, and 100% street legal grocery getter. The best track time with the pictured stock block motor was 9.90 1/4 mile. I am currently building a 255 ci stroker motor, and contemplating going pro-touring with it instead of drag racing.
MonzaRacer
03-29-2009, 11:48 AM
I have been planning on a 283 for my Monza. Was thinking of trying (2) T3 or T4 such as the ones like they used on Fords 2.3 Tbird engines.
The turbo match program I found matched these same specs, and even (2) IH tractor turbos.
Still out in limbo on turbo project.
shmoov69
03-29-2009, 07:51 PM
They will work on any small block just fine, a bit too small, but work juuuust fine!
Trust me! LOL.
Git'r done!
Nik@PTP
04-05-2009, 01:36 PM
HI, I'm new and young to the forums, but i'm in the process of building a Srt4 Powered 1986 corolla for a Drifting Project.
Its Great to see a Variety of different swaps, and builds.
Keep it up!
wickedred
04-05-2009, 04:38 PM
I have several turbo setups in the works. It just sucks none of them are mine.
slownova73
07-20-2010, 06:07 PM
Im gonna give it a shot.......bump
good thread, too good to die lol
jilge71
07-20-2010, 07:16 PM
oohhh ooohh add me add me...lol 5.3 ls with a zo6 cam and springs and car intake with speed inc fuel rails and 60# motrons and a mpt70 single turbo. ill try and get pics soon
DButler
07-21-2010, 10:28 AM
67 Camaro. I have a 355 with mild cam. Twin hybrid t3/t4 turbos. BG400 pump, aeromotive boost ref. regulator. air to air intercooler, custom headers, carb shop carbeutor. I have Innovate LM2. Car is currently being tuned. The carbeutor is on its way to Cali as we speak. I have been building it for bout 8 to 10 months. I haven't got to drive it yet and I am looking forward to it!! Check out my pt garage for pics. Also has anyone here used a Carb Shop carb? Would like to hear some reviews.
zwhitney
07-21-2010, 08:21 PM
It's an old thread but here goes.
78 Camaro, 406ci SBC, accel gen 7 DFI, twin t04b's, intercooler, etc. New wheels and tires later this week...
my72vette454
07-22-2010, 03:05 AM
I started this thread in nov of 05, sure are lots of fun projects posted on here now, keep em coming! My project has been pretty much unchanged since I posted my stuff in 05, the last 3 years have sucked financially and extra time wise but I am still tinkering with my project. The next thing I need to do is buy some wheels then I can start on my frame build, I cant do much to the exterior or interior till I get the chassis done.
BanditDave
07-22-2010, 04:28 AM
1969 Olds 442
6.0L 4L80e
74 fully divided 74mm turbo
Chasing down 10.50s driving to the track.
705.0Merc
08-04-2010, 06:06 AM
https://www.pro-touring.com/forum/vbpicgallery.php?do=hall&u=6180
70 Cougar
272/285 all motor
409/469 9 psi t-61 .81 turbo 12.8 @115 2.2 60' street tires. I gained 14mph in the quarter with the turbo.
I have a t70 .68 on now, no dyno # or drag times.
89 5.0 stock bottom end with Steeds no 18 cam with 1.7's and e7 cnc powerheads. Performer rpm intake Holley 600dp
Tremec 3550 5 speed
9" rear with 3.25 tracloc.
mnm99
08-04-2010, 09:18 AM
In build process. 1968 Camaro Convertible. Twin 60-1 Garrett, 44mm wastegates. Headers are 304 stainless. I did all the fab work...
Nothingface5384
09-26-2010, 07:08 AM
I have a twin turbo buick 350 in the works...been on hold due to random personal issues/$$ ..but it'll get done this summer
just ebay t04e turbos...i'll eventually switch to the t35 mirage water/oil turbos if the others crap out
retrotek powerjection III
sheetmetal s/p intake
might as well add an intercooler to the parts pile lol
59twin turbo el camino
10-08-2010, 11:18 AM
i am doing a 59 el camino keitblack 550ci .twin 88 precision. rossler t210 with a gearvendors.
https://static1.pt-content.com/images/pt/2010/10/elcaminomooi-1.jpg
https://static1.pt-content.com/images/pt/2010/10/4-1.jpg
https://static1.pt-content.com/images/pt/2010/10/DSC00040-1.jpg
https://static1.pt-content.com/images/pt/2010/10/STA41109-1.jpg
https://static1.pt-content.com/images/pt/2010/10/camredj-1.jpg
https://static1.pt-content.com/images/pt/2010/10/STA41422-1.jpg
https://static1.pt-content.com/images/pt/2010/10/STA41355-1.jpg
:smoke:
Larry Callahan
10-08-2010, 08:08 PM
This has got to be one of the oldest active threads on the forum. LOL!
I thought I would pop in again.
My 10 pounds of stuff in a 5 pound sack.
407ci Dart Little M block, Trick Flow CNC heads, Turbonetics 60-1 Hi-Fi .69ar P trim about 8.5:1 and 10-12 pounds of boost. Tons and tons of fun.
https://www.pro-touring.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=32923
exwestracer
10-08-2010, 11:31 PM
Nothing to compare to all these monsters, but if you're on a budget...
Edelbrock 350 Pro-Flo EFI crate engine (ZZ4 with E-tec heads). 375hp & 360 lb/ft (engine dyno baseline)
Added a single Holset HX35 turbo and intercooler off a Dodge Cummins diesel, 43lb injectors, and dynoed 530hp & 604 lb/ft.
Thats 150hp and almost 250 lb/ft... For 900 bucks total (exhaust, MAF, everything)... And it didn't break under 15lb of boost.
Read about it soon in Auto Enthusiast.
Procharmo
10-09-2010, 04:08 AM
:smoke:
what a great car do you get ,i love it .and the twin procharger set looks awsome . hope to see you sometime on santapod next year. greetings jacco,
Hi Jacco, thanks for the compliments. I really do hope to get to the Pod because your TT Camino is off the hook......Trust me mine is a bit of a junker close up. I can see the engineering and attention to finish in yours is so extreme.
David
Larry Callahan
10-09-2010, 07:03 AM
Sounds cool. Let us know when it's out.
exwestracer
10-11-2010, 10:06 AM
Camee says Jan 2011 issue if they get all the releases signed, etc.
ledslinger
11-19-2010, 01:23 AM
I've been putting in as much overtime as possible to save up, and I'm committing myself to run twin turbo. I'm still reading, and learning, but I am determined. I'm currently running a 396/375 with factory aluminum heads. I will probably get flack for wanting to turbo, but I can't help it. I'm committed.
I want to run EFI; Accel DFI Super Ram looks really appealing. I want to make my own plenum.
I still am reading more about how to build my system, and would love your opinions. I gotta do it.
throw out some ball park ideas.
-Matt
exwestracer
11-19-2010, 10:04 AM
-Matt
Matt,
I'm personally a big fan of that type of manifold. We are trying something a little off the wall with project "no-buck". I pulled the plenum box off and made plates to adapt 2 4bbl throttle bodies onto the top of the tunnel ram. It's almost done...look for updates in the power adders forum.
IMO, the bore size on the 396 really won't take the best advantage of your cylinder heads, but the turbos will make up for a lot of that.
ledslinger
11-19-2010, 04:55 PM
Here's a couple renderings of what i'm thinking of doing for a plenum on the accel super ram manifold
-the logs won't be seperated
-i want to run 2 circular throttle bodies
-i'm considering extending the runners on the plenum
https://static1.pt-content.com/images/pt/2010/11/3423424-1.jpg
https://static1.pt-content.com/images/pt/2010/10/MGInjectionConcept-1.jpg
here's my motor with an air gap and ultra hp
https://static1.pt-content.com/images/pt/2010/11/76650_176885365659791_100000149873371_67-1.jpg
18 hours overtime last pay period, savin up more and more.
-I got the motor with a standard bore stock spec bottom end, and swapped solid mechanical for comp hydraulic roller cam and rockers.
-I want to find the ideal rotating assembly for turbo, and would really appreciate your opinions.
-same goes for turbo's, injectors, fuel system, etc.
-I had an aeromotive a1000 system, but ended up trying out a few different mechanical pumps, and am running a simple carter for the street, thats worked better than anything else.
Ray- i just realized that your a wyotech instructor?
i started this project when I was 18, and wanted to get it on the street before I went to wyotech for chassis fab and engine building in Sacramento.
how do you recommend the best way to go about getting enrolled? can you get scholarships or grants?
James21
12-09-2010, 10:39 AM
Working on my nova at the moment. Im only into it 850 bucks so far. Its a budget build. Its a single turbo (5.9 diesel turbo) I had it rebuilt. I have a custom manifold that's getting a little work done to it right now. I'm hopping to get to 450-500 HP. The turbo is a 60 trim with a 1.0 A/R. It should spool real quick, my motor tops out at 5500 RPM so it should run pretty well with the flow of the turbo. I'm running a qjet carb but will prob be replacing it with a blow through set up. I'm only going to run 8lbs of boost.
The nova
https://static1.pt-content.com/images/pt/2010/08/burn6-1.jpg
Turbo (not as pretty as most of these set ups but hopefully it will run good)
https://static1.pt-content.com/images/pt/2010/12/IMG00050201011142016-1.jpg
BB_Mike
12-13-2010, 11:18 AM
Building a 1971 Chevelle.
540 dart block
Twin 76mm turbos
FAST XFI 2.0 EFI
Air conditioning
Inner fenders
Overdrive
275 front tire, 315 rear tire.
Pretty pictures will come sooner or later. hard enough finding time to build it. This is not a commissioned build by any means.
twinturbo69
12-14-2010, 09:39 PM
69 Camaro Project Car
383 Stroker, Turbo 400 Trans
Stock GM Block (my weak link!)
Eagle forged rotating assembly
Dart Pro 1 215cc Aluminum Heads
SRP 8.5:1 forged pistons
FAST EFI, Holley Stealth Ram intake, 80 lb/hr injectors
(2) Turbonetics T04B 60mm turbos
730 HP/750TQ before the exhaust headers were changed out to higher flowing cast manifolds ( I expect a hefty increase in power due to how much the original system was restricted near the T4 mounting flanges)
alfatwin
01-09-2011, 03:52 PM
'74 alfa romeo gtv, sbc twin turbo injected? 5 speed manual, roll cage.... long, ongoing, forever project (or untill my son hits 16 yrs whichever comes first) I put a question in this section under rotomaster, if you guys can help me with it that would be great. these rides sound great, good to find likeminded carfools out there!
mnm99
01-17-2011, 05:35 PM
Hey Larry. I spoke with you a few times about your build. I finally finished it. Here's my 15 pounds in a 5 pound sack...LOL43848438494385043851
ProTouring66Impala
01-20-2011, 09:44 AM
1966 Impala Coupe
L76 and 6L80E from a 2009 G8 GT
Genn-ttR Modified GTO Twin Turbo Kit
Its alomost ready to roll. Pics very soon...
94SNGLTURBO
01-20-2011, 01:18 PM
65 chevelle ls2 6.0 motor with custom single turbo garrett gt40, 4inch dp and exhaust 7.5 psi is all i wanted to run built 4l80e 500rwhp and 550rwtq
my72vette454
01-22-2011, 07:15 AM
It cool to see people keep adding to this thread, lots of interesting projects going on out there. Nothing much has changed as far as my turbo project is concerned, been on the road almost four years now and quite enjoying it. I finally collected the last pieces I needed to start on a new frame for my 72 vette. I bought an extra frame and am doing a c4 suspension conversion on it which will give me a better rear end, better tires, lighter suspension components, better brakes and better steering. Keep postin them up!
shmoov69
01-22-2011, 08:16 AM
Update on my junk!
I put a couple T3/4's on it. They are Super 57 compressor's and Stage 3 exhaust.....in place of my stocker ThunderBird T3's.........whoooooaa maaaama!!!! Needless to say, quite a difference!! And I haven't changed any timing yet, should be even better by changing the curve a little.
COPO-RAT
02-02-2011, 06:31 PM
Awesome! I'm putting together a blow through (hopefully to be converted to FI) turbo set-up for a 250ci inline 6 chevy going in our '64 Bel Air Wagon! Would love to see pics of your truck system.
Six_Shooter
02-06-2011, 10:46 AM
Here is my current turbo toy:
This was just after I got it running a little over two years ago.
Since that picture I have changed the location of the air filter, added an intercooler (ran it for about 2 years without an IC, though I had the tubing routed out to where the FMIC was to be installed. lol), I have changed to DIS as well. I really need to get some updated pictures.
It was carburated and N/A when I got it, I used some stock Nissan parts and some custom parts to get it all together and working. It is running of a Delco (GM) ECM that would be found in the Turbo Sunbird and Syclone/Typhoon, with custom code and tuned by me. I can't wait for spring, the FMIC REALLY changed the way it pulled, way more than I was expecting. I should have built it much sooner. lol
I'm using a BW turbo pirated from a 6.5L Diesel, Ford 3.8L SC injectors (which will be replaced with larger ones this spring), Gm 3100 V6 TB with a custom adapter plate, and a bunch of other misc. parts. The exhaust is a 3" exhaust that I TIG welded and fits tight under the car, ended with a Moroso Spiro-flow muffler.
It is in this (also and old outdated picture):
Here is an old video of it running a couple years ago, just after converting it to DIS.
http://vimeo.com/14016010
And old turbo project I built about 9 years ago, which has long since been pulled apart:
It was a 3.2L 60 degree V6, I started with a 1986 2.8L block, used a FWD 1992 3.1L crank, FM pistons, Ford 19 lbs/hr injectors (which were way too small), 1995 Buick Skylark 3100 heads and intake, home made headers, Ford Turbo Coupe T3 turbo, Mitsubishi Strarion FMIC, and many other misc bits and pieces.
In this Jimmy below, which I still have but have a different path for the power plant now.
355 holley stealth ram, working on swapping to a LQ4. not real happy with Holley stealth ram and comander system.
64duece
02-13-2011, 09:05 AM
I've done a few turbo setups with the Holley Stealthram system...worked out pretty good. Sounds like your already moving on to another setup...if there's anything I can answer to help with the Holley, just ask.
Torbjorn
02-13-2011, 12:59 PM
Shot at 2010-09-29
65 Chevelle with a -93 Northstar engine. Slightly lower static compression and Crower steel rods.
Small Switzer Turbos and home made exhaust and intake manifoils.
Electromotive Tec 3 .
The Idea wasn't to set any world records with this one. Should theoreticaly make 600hp at 14,6 psi
FirstGenZq8
02-13-2011, 09:55 PM
It was a 3.2L 60 degree V6, I started with a 1986 2.8L block, used a FWD 1992 3.1L crank, Pistons, FM pistons, For 19 lbs/hr injectors (which were way too small), 1995 Buick Skylark 3100 heads and intake, home made headers, Ford Turbo Coupe T3 turbo, Mitsubishi Strarion FMIC, and many other misc bits an pieces.
wow, i remember this truck and i remember your posts from SSF.com! man it's been awhile.
do tell!
i will be holding off on the LQ4 swap for a year or so, have another frame i will be modifying and will convert with the frame swap. i had a few issues with Holley bad intake casting, would not seal to heads properly causing vacume leaks, drove me crazy. After many tech calls and sending them gaskets and the intake base pointing out the defect holley sent me a new manifold. next problem defective injector.
i now have it running pretty good but the throttle response just does not seem real crisp, i also have some issue with WOT looks like i am runnign out of fuel pressure, have about 38psi idle under boost it will rise to about 42 and then start to drop. i am running a the Holley fuel pump and fuel reg, holley said the pump is good for 700 hp and the fuel reg will work in boosted applications. i bought a new ajustable regulator i havent swapped it since i think the issue is the pump.
i plan on driving this setup one more summer, if you have any tips ideas that would be great.
i am running 55lbs injectors and 10lbs of boost.
Joe
what type of setup did you go with injector size, pump and regulator.
64duece
02-15-2011, 01:09 PM
Joe,
First thing you need to sort out is the fuel pressure issue. It needs to rise 1:1 with boost to keep fuel flowing.
Throttle response is in tuning and your combination. The Cmdr950 can be cumbersome with respect to the AE/TPS and AE MAP as there's no indication of movement. I usually recommend changing the entire row up/down as it's difficult to know which cell your using. AE vs TPS has the larger impact for what your describing. Next, check the timing...ensure it matches ECU vs balancer. Once you've verified that, you can check your curve to ensure you have optimum values.
700hp is a relative term. Relative to voltage and fuel pressure. I usually recommend upgrading after 650hp on moderate boost (-12psi and above). We use these pumps all the time as primary pumps and add a 2nd or an A1000/Eliminator/Pro Series pump in parallel for additional volume. They're super quiet and last awhile.
I know Holley had some issues with regulators on the Stealthram units. We had one or two calls about it. The adjustable regulator should get you sorted out. We've used those along with various injector sizes in a few blower/turbo cars. Six or seven years ago I ran a single turbo SBC with 160lb injectors and a Cmdr950 in the mid 7.60's @ 180+mph. We turned the boost back and ran consistent 8.50's all day. There are other options out there today but....they still can do the basics pretty well.
Thanks Dennis, i will get the fuel pressure issue addressed first. Good to know the 950 has the capabilities.
65 ELKY
02-25-2011, 11:31 AM
https://static1.pt-content.com/images/pt/2011/02/20101011134245-1.jpg
https://static1.pt-content.com/images/pt/2011/02/20101013122112-1.jpg
On my 65 Camino im running a Single MP t-70 Holley750 blow thru.
Six_Shooter
02-25-2011, 03:35 PM
do tell!
SSF.com?
I want to keep the power plant under wraps for now, at least until I have it in my hands. I'm still trying to find one for cheap. It won't be your common S-10 swap though. ;)
FirstGenZq8
02-27-2011, 03:16 PM
SSF.com?
The Franken60: http://www.s-seriesforum.com/forum/showthread.php?t=45872
Six_Shooter
02-27-2011, 04:59 PM
Wow, I haven't been on that site in about 5 years. lol
mrobertweiss
02-28-2011, 01:36 PM
Starting to test run the studebaker twin turbo, 299 CI stude V8,garret 2860RS units, mass-flo efi, viper T56 6 speed. Running well at cruise, no detonation at modest 6-8 lbs boost on pump gas 93.Goals were appx 400HP and 10-12 # boost. Still issues with the EFI, some over- compensating dashpot function, I think, on deceleration at low gears , which is kind of a nuisance.https://static1.pt-content.com/images/pt/2011/02/IMAG0171-1.jpg
1Bad68camaro
05-02-2011, 12:53 PM
Doing my research now to do a single turbo setup on a 68 Camaro with LT1/T56 setup. Hoping to find a very budget minded way of doing it. Looking for 450rwhp. Currently with mild ported heads/intake and cc306 cam and full bolt-ons looking at 350rwhp. So nothing crazy. I think a 100rwhp increase shouldnt be hard with 6 or 7psi on a stock rebuilt bottom end. Then down the road I can forge the bottom end and put a bigger turbo to look for much higher numbers.
1970 TT Rustang
05-03-2011, 01:58 PM
Hi guys iam running a bill mitchell 427 with twin rear mounted 60 trims iam currently redoing the wireing and putting in an accel dfi. Iam hopeing for 580 rwhp with my setup i might do e85.
46531
46532
46533
mwhizard
08-28-2011, 11:20 AM
1971 Camaro Z28, TT LS2, 4" stroke SCAT crank & H beam rods, Racetec 8.5:1 forged pistons, Precision Turbo 6265's w/.82 AR T3 housings. Stock Cam, 243 casting heads, inverted C6 exhaust manifolds, Injector Dynamics ID1000 injectors, HP Tuners management, capable of 21psi, so far DYNO'ed to 622 RWHP 630 RWTQ on a MUSTANG Dyno at 13.9 psi.
https://static1.pt-content.com/images/noimg.gif[/IMG]
http://contour.com/stories/mission-raceway-park/embed?map=false&width=960px&height=540px
http://www.ls1tech.com/forums/conversions-hybrids/893822-marks-ls1-2nd-gen-camaro-build.html
king869
11-20-2011, 11:14 AM
[QUOTE]70 mustang fastback 427 bill mitchell twin 60 trim turbos remote mount. Currie rear air ride gear vendors tranny ssbc brakes 4link and accel dfi.[QUOTE]
Is that one of the STS systems? How easy was the install? How do you like it? I want to run twin turbos but just don't know if i want front or rear mount on my 72 Nova...
frojoe
11-30-2011, 12:20 PM
Stock 6.0L LQ4, TC76, T56, hope to be on the road real soon...
51889
51890
61221
61222
tiznodd
12-13-2011, 06:26 PM
LQ4, T56 and a Precision 7675. It's 99% done.
52536
shmoov69
12-14-2011, 09:22 PM
Sweet!!
SS PUNISHER
02-03-2012, 04:38 PM
I just picked up a garrett off a 06 6.0 powerstroke, anybody got specs on these things??
BulldawgMusclecars
02-04-2012, 11:57 AM
I just started my "Project GNXcess" 1983 Regal T-Type. Its getting a forged 408 (LQ4 based) with twins, and a T-56. I'll post pics when I have something to show other than teardown!
LSXfan
02-10-2012, 08:24 AM
64 Chevelle LS1/T56 turbo project in progress hope to have it done by March
stock shortblock LS1 (9.6:1 comp)
TC78 w/ 1.05 A/R
ported #317 heads
twin Walbro 255 (second pump on a 5psi Hobbs switch)
-8 AN feed
-6 AN return
3" intercooler
#80 SD injectors
will run E85
Turbo is in:
INTMD8
02-29-2012, 11:34 AM
Hi :)
https://static1.pt-content.com/images/pt/2012/02/eldoradobrougham219-1.jpg
6D9 Matt
02-29-2012, 12:11 PM
Oh now this is my type of thread. :D
mnm99
03-07-2012, 04:12 AM
Finished.....
RSX302
03-12-2012, 09:06 PM
Hidden Turbos....Hot of the press..49 miles and counting
370 LQ9, Forged Piston and Rods, AFR 215 LSX heads, Edelbrock Airgap manifold, GM Distributor conversion, Twin Garrett GT2871 turbos with .86ar turbine housings, Air/Water Intercoolers (still needs water plumbing).
https://static1.pt-content.com/images/pt/2012/03/DSCF00013-1.jpg
https://static1.pt-content.com/images/pt/2012/03/DSCF00023-1.jpg
https://static1.pt-content.com/images/pt/2012/03/DSCF00034-1.jpg
https://static1.pt-content.com/images/pt/2012/03/DSCF00052-1.jpg
There they are!
https://static1.pt-content.com/images/pt/2012/02/DSCF00101-1.jpg
https://static1.pt-content.com/images/pt/2012/01/DSCF00071-1.jpg
syborg tt
03-13-2012, 07:56 AM
Okay first off how the heck did you do a motor swap and all of the fab without hurting the engine bay.
second - Simply Awesome looking
There they are!
RSX302
03-13-2012, 10:12 AM
Thx Marty
Turbo installs are always lots of creativity, patience & staring at it with a beer in hand for many hours! Many times asking "Where do I run this, how do I get that in there, What if I move that"
It did require new motor mounts and repaint of the front clip. Engine is 1" further forward due to longer input shaft and 1.5" taller then the SB Ford. Dry sump system help too. No crossmember issues to deal with.
syborg tt
03-13-2012, 10:29 AM
Thx Marty
lol - I remember doing that with Dave over at Comp Fab when we were working on my truck. However I was drinking Ice Tea had a small problem with the Liquor. Once we cut out the firewall it was so much easier to do.
You need to post some more pictures
RSX302
03-13-2012, 09:17 PM
Here is a link to more pics
http://s1224.photobucket.com/albums/ee379/rderaad/
syborg tt
03-14-2012, 06:29 AM
Thanks for the link - Looked at all of the pictures
Larry Callahan
04-19-2012, 11:29 AM
How are things going on your ride? MotiV8r is going through a change. It's at JCG and a Holley Stealth Ram is going in.
fastfail
04-19-2012, 03:01 PM
Now this is the proper topic for pro touring, not lets see how big your rims are, lol.n These are sick cars.
This is a great thread. Ill try posting a few pictures of my hoop-ty. It's a 1970 chevelle, world products block/383ci, AFR's and a MPGT45 turbo, Tremec TKO and a 9 inch. My original goals were a 10 sec. quarter mile time so thats the direction I started heading with it. Well after I was introduced to this site a few months back I really want to build something that handles. I'll be adding some things here and there to my current build to help with handling but I need to stick to one path and just finish the damn thing. anyways- hoping for 600rwhp which I don't think should be a problem. Hope you people like it:
another, 3.5" down pipe to full 4" exhaust.
as you can see this picture is different than my first. I changed the routing of the down pipe for clearance issues.
E.rodz
06-07-2012, 09:36 AM
here is my project taking all my time.twin 57mm on a 5.3 hope to have it on the road in a couple of weeks.
https://static1.pt-content.com/images/pt/2012/06/IMAG1076-1.jpg
https://static1.pt-content.com/images/pt/2012/06/IMAG0971-1.jpg
Chevy406
06-19-2012, 09:10 AM
52536
Can you give some more details and/or pictures on the air filter and inlet duct. Your turbo placement is very similar to my twins in '69 Nova, and I want to pull fresh air from somewhere behind the headlights.
I am going to hold off posting any pictures of my home built junk until it is a little more presentable. It's a pretty high bar set in this thread...
tiznodd
06-24-2012, 04:30 PM
It's nothing fancy, just a 4" 90 degree silicone bend into a 4" piece of stainless pipe aprox 4" in length, going into a generic K&N cone style filter. If you look at the turbo from the top, it's clocked about 10 degrees clockwise. This was done so the elbow would clear the radiator. My tuner wasn't thrilled with the silicone elbow - he thinks a thicker rubber piece is better because the thin silicone style can suck themselves shut if the filter doesn't flow well enough. I didn't have that problem at 12psi.
https://static1.pt-content.com/images/pt/2012/06/20111204_160241_471-1.jpg
mnm99
12-23-2012, 07:54 AM
Haven't been here for a while. It's been 2 seasons and it's running perfect with no problems just want more. Right now I have a stock 350 290hp GM crate pushing 5lbs. I built the system around this engine mainly as a mock up for a new motor. With this setup I'm around 400hp.Next summer a new engine is going in. I'm going with a fully forged Dart SHP block, Diamond pistons and AFR heads. All said and done I'll be running 15-20lbs of boost Hopeing for close to 1000hp. I will keep everyone updated.....
