View Full Version : Clayton Machine Chevelle throttle pedal (or similar)
chuckd71
04-18-2016, 06:43 PM
My oem pedal sort of sucks, I'd like something at least a little adjustable and perhaps a little prettier. I have a 71 Chevelle with a DBC FAST 92, so if you have a cable to go with the pedal I might need that too.
This is what I'm thinking about http://www.claytonmachine.com/product/anodized-billet-throttle-assembly/
Or something similar.
raustinss
04-18-2016, 08:39 PM
if thats what you like why dont you order it ....? is it no longer avail.?
chuckd71
04-19-2016, 07:01 AM
Using that logic there wouldn't be any need for the classified section would there.
Not that there is any reason to explain a wanted post in the parts wanted section, but I won't even be able to install it for weeks or months, and it's possible there is someone out there that has one they are looking to get rid of; in that case we both win. Then there is the "or similar" part, because I suspect there might be other companies I don't know about making pedals, some of which might be better or more appropriate for what I'm doing. If nothing turns up between now and when I need it then I'll order it from MCB like I do most parts. Nothing devious or unusual going on here.
Didn't you post an add looking for readily-available accessory drive parts? They can be bought at any dealer....?
raustinss
04-19-2016, 11:53 AM
no i wasnt looking for anything ....did awhile ago looking for info on aston martin door handles (int). anyways stellar points i guess , i assumed you knew exactly what you wanted ... guess thats further proof to what happens when you assume. if your looking for pedals go back and check out clayton machine works truss style pedals which bolt into a chevelle and have the option for cable or dbw . if your a little ocd like myself they sell a matching style door handles and window cranks. little different then the style you were looking at before but quite nice
