View Full Version : No Brakes After Turning HELLLPPPP!!!!!!
72_Nova
04-02-2016, 07:09 AM
Like titled I am having a problem with losing brake pressure after I turn. If I drive straight forever I have no problem but the second I turn semi hard the pedal falls.
I am running Wilwood 14'' spec 37 rotors front and rear. 6 piston nickel plated calipers front 4 piston rear both with knock back springs. Wilwood 15/16 Master cylinder proportioning valve and brake pedal.
So far I have changed calipers. Changed Master cylinders twice (and bench bleed twice) Changed wheel bearings Changed upper and lower ball joints. Swapped wildwood rear retainer plate to Currie retainer plate. Changed steering tie rods and bleed the system at least 200 times. I am really out of options here and need to figure this out. Any input would be helpful.
HandOverFist
04-02-2016, 07:34 AM
Maybe get it up in the air an observe the flex lines while turning lock to lock?
parsonsj
04-02-2016, 07:37 AM
It is almost certainly knock back causing this issue, most likely coming from the rear. Tell us about your axle setup.
72_Nova
04-02-2016, 07:55 AM
So the rear is Moser M9 with tru track and 31 spline axels and tapered bearings. I have already replaced the bearings and wilwood retainers with currie retainers. Their so no play at all in the rear. I just installed these new retainers yesterday
dontlifttoshift
04-02-2016, 08:42 AM
Another thing to check, make sure the front calipers aren't hitting anything when you turn. Unlikely, but check anyways.
parsonsj
04-02-2016, 12:45 PM
Their's no play at all in the rearHow did you verify that? One thing to try would be eliminate your rear brakes. Cap your rear brakes at the junction where it goes to the axle. (you'll still have 80% of your brakes). Drive slowly to a secluded spot and see if you still have knockback. If you don't then you can quit worrying about the front brakes.
parsonsj
04-02-2016, 12:51 PM
Also, what are your wheel dimensions? Diameter, width, offset/backspace?
72_Nova
04-02-2016, 06:15 PM
When i say their is no play I mean physically as a human pulling and pushing the rear axle in and out of the housing their is no play now with the Force of the car idk if it's moving but when I push and pull it doesn't budge .
72_Nova
04-02-2016, 06:16 PM
Wheels are 18x9.5 with a 20 mm offset and 6" back space
parsonsj
04-03-2016, 04:18 AM
Your wheels are reasonable: "deep-lip" wheels have more leverage on the axles than centered wheels.
I'd eliminate the rear brakes, and see if the problem goes away.
72_Nova
04-03-2016, 04:41 PM
I'm going to try that tomorrow since I need to know if it's front or rear.
chpr1972
04-12-2016, 07:41 AM
72 Nova
Did you get the brakes cured and what did you find? I have this same problem and the answer I got was live with it or change the calipers to floating ones.
72_Nova
04-12-2016, 09:40 AM
72 Nova
not yet ive been just dealing with it but I'm installing residual valves tomorrow so we will see what that does. Still haven't figured out if its the front or back but I will do that tomorrow before I install.
mincharlie
04-12-2016, 02:05 PM
Had same issue with my wilwood set up, mainly on hard slaloms. It was pad knock back, installed caliper piston springs like they have in some porshes to hold pads against rotor. Works great and didn't have to add residual valve.
dhutton
04-13-2016, 04:42 AM
Lots of guys have tried residual valves to cure pad knock back without success.
Don
72_Nova
04-13-2016, 06:23 AM
Ya I thought that would fix the issue but my new calipers all have the springs in them and they don't help...
72_Nova
04-13-2016, 06:26 AM
Don
Well at this point in time I have replaced everything in the car except the rear end itself which is a new M9 just purchased 3 months ago... So its either residual valves or drop 4k on a floater...
Hugger67RSSS
04-13-2016, 06:53 AM
Like others have said residual valves will likely not help. They didn't for me. I switched my housing to corvette style hub bearings and fixed the problem. You can use your same housing and save some money that way.
TheJDMan
04-13-2016, 04:53 PM
A call to Moser might be in order to see if they can weld floater snouts on your housing. I know Moser sells floater hub kits so you just need the snouts welded on.
72_Nova
04-16-2016, 07:21 AM
Sooooooo blocked off the rear lines yesterday and guess what... Still doing it so the knock back is in the front... Where? Idk I have replaced everything but the spindles and hubs...
dhutton
04-16-2016, 09:04 AM
What is the clearance between the wheel and caliper? Any chance the wheel is flexing and hitting the caliper? I am pretty sure I remember David Pozzi posting a pic of this.
Don
72_Nova
04-16-2016, 09:42 AM
I wish it was that simple but I have plenty of clearance I'm starting th think its the wilwood hubs...
Hoppie
04-18-2016, 04:40 PM
I'm interested what you find out. I've been chasing the same demon for awhile. I converted to a full floating rear which improved it a ton but it still falls and gets soft after a couple turns.
I have a Baer system with the Wilwood master cylinder. it's really frustrating. I've ended up taking it to professionals and they are stumped too.
another69
04-18-2016, 05:29 PM
Could you post a pic of your fronts? It may help. You don't have excessive play at the front wheel bearings do you?
72_Nova
04-19-2016, 06:37 AM
Here are a few pictures. The bearings are new with no play I just replaced them thinking that was the problem. Last picture is the only pic I have of the arms and spindle without the rotor and hub on. It was taken a year and a half ago
https://static1.pt-content.com/images/pt/2016/04/KjXsn8z-1.jpg
https://static1.pt-content.com/images/pt/2016/04/ERaJoEJ-1.jpg
https://static1.pt-content.com/images/pt/2016/04/xCO9Hrb-1.jpg
chpr1972
05-17-2016, 01:05 PM
Altho you say it is coming from the front brakes, are you sure that the rear axle bearing retainers are installed correctly? I have a lot of play in my moser rear end and according to curry and moser, the lip on the retainer goes towards the bearing, not away from it. With that 2 lb check valve in the rear brake system you will not have any play at the rear. pull the brake pads out and then shake the axle. I had 1/4 ' of play. The retainer was put in wrong.
440AutoX
05-17-2016, 02:30 PM
Had the same issue with our new Wilwood 13" rotors and 6 piston calipers on our 1970 Dodge Challenger this past weekend...we would turn back and forth and push the pedal down it would go to the floor but a quick let off and push the pedal again and they were there. Dad tightened the hubs up till there was no play at all and nut was tight (set to normal tight and then back the nut off a quarter turn to begin with) and it helped so we are thinking the bearings aren't set completely tight where they are supposed to be.
72_Nova
05-18-2016, 10:42 AM
Retainer plat is installed correctly with no play what so ever in the rear
72_Nova
05-18-2016, 10:44 AM
I wish that was the case with mine. I have changed bearings 3 times now and have tried tightening with and with out the back turn. Neither works for me
