1kwikgt
03-09-2016, 05:39 PM
1991 mustang coupe. This is an original black 5.0 coupe. Started by doing mini tub, 10 point cage, through the floor subframe connectors all from Wolfe racecars. Smoothed the engine compartment and redid all of the undercoating on the car. Then did a built 8.8 with mossier axles and c-clip eliminators. Full swap from an 03 cobra including engine, t-56, dash, and full wiring harness. Everything works including power windows. Engine was taken down to short block and resealed and added arp head studs. Has a home ported blower and 2.93 pulley. Full return fuel system with aeromotive fuel cell/a1000 pump combo, fuel rails and pressure regulator. 03 tenth anniversary brakes, brand new chrome 03 wheels with brand new Nitto tires. This car is fully built from the ground up and if you really want to go fast put a large whipple on and make as much power as you want. All of the supporting mods are there. Asking $20,000. 817-9two5-58four0
Chassis -
Minitub from Wolfe Racecraft
12 point cage from Wolfe Racecraft
Through the floor subframe connectors from Wolfe Racecraft
Double adjustable upper control arms with solid bushing from Wolfe Racecraft
Double adjustable offset lower control arms from Wolfe Racecraft
Adjustable anti roll bar from Wolfe Racecraft
Adjustable upper inset spring perches from Wolfe Racecraft
QA1 springs
QA1 Adjustable shocks
Stifflers trans mount
AJE Tubular K-member
03 cobra lower control arms
H&R race springs
Stock struts
Quick ratio steering rack
Steeda bump steer kit
Brakes/ wheels-
03 Cobra Hydraboost
03 cobra Hydraboost lines and p/s lines
Willwood brake adjuster
All new hard lines
Braided stainless soft lines
03 Cobra front hubs
03 Cobra 10th anniversary brakes on all 4 corners
03 cobra chrome 17x9 wheels
Nitto 275/40/17 tires
Rear End-
8.8 with welded axle tubes and braced
C-clip eliminators
Moser axles
3.73 gears
Ford Racing cover brace
Engine-
Factory 03 cobra engine, resealed, ARP head studs
03 Cobra full wiring harness and computer
Battery relocated to trunk
Metco idler pulleys
Ford Racing a/c delete
Changeable supercharger pulley hub
Head cooling mod
03 Cobra Radiator & fan
NGK TR6 plugs
Canton radiator and Intercooler expansion tanks
Moroso p/s reservoir
Fuel system-
Aeromotive fuel 20 gal. Fuel cell with internal A1000 pump
-10an feed line to Aeromotive fuel filter
-8an braided line to rails
Division X fuel rails
60 lbs Siemen Deka injectors
Aeromotive fuel pressure regulator
6an return line to pump
Transmission-
03 Cobra T-56
03 Cobra flywheel
Spec clutch
Adjustable cable, firewall mount and quandrent
MGW Orange handle shifter
03 cobra drive shafT
Exhaust-
MAC Ceramic long tubes
lethal performance x-pipe
Flow tech cutback dumps
Last 2 pics are links to vids.
http://s114.photobucket.com/user/1kwikgt/media/image.jpg5_2.jpg.html] (https://static1.pt-content.com/images/pt/2016/03/imagejpg5_2-1.jpg[/img][/FONT][/COLOR]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg1_4.jpg.html] (https://static1.pt-content.com/images/pt/2016/03/imagejpg1_4-1.jpg[/img][/FONT][/COLOR]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg4_2.jpg.html] (https://static1.pt-content.com/images/pt/2016/03/imagejpg4_2-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg2_2.jpg.html] (https://static1.pt-content.com/images/pt/2016/03/imagejpg2_2-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg3_2.jpg.html] (https://static1.pt-content.com/images/pt/2016/03/imagejpg3_2-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg2_1.jpg.html] (https://static1.pt-content.com/images/pt/2016/01/imagejpg2_1-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg5_1.jpg.html] (https://static1.pt-content.com/images/pt/2016/01/imagejpg5_1-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg7_1.jpg.html] (https://static1.pt-content.com/images/pt/2016/01/imagejpg7_1-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg4_1.jpg.html] (https://static1.pt-content.com/images/pt/2016/01/imagejpg4_1-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg6_1.jpg.html] (https://static1.pt-content.com/images/pt/2016/01/imagejpg6_1-1.jpg[/img]
http://s114.photobucket.com/user/1kwikgt/media/image.jpg3_1.jpg.html] (https://static1.pt-content.com/images/pt/2016/01/imagejpg3_1-1.jpg[/img]
http://i114.photobucket.com/albums/n269/1kwikgt/IMG_1068.mp4] (https://static1.pt-content.com/images/pt/2016/01/th_IMG_1068-1.mp4[/img]
[COLOR=rgba(0, 0, 0, 0.701961)][FONT=UICTFontTextStyleBody]http://s114.photobucket.com/user/1kwikgt/media/image.jpg6_2.jpg.html] ([URL)
Chassis -
QA1 springs
H&R race springs
Stock struts
Brakes/ wheels-
03 Cobra Hydraboost
All new hard lines
03 Cobra front hubs
Rear End-
C-clip eliminators
Moser axles
3.73 gears
Engine-
Metco idler pulleys
Head cooling mod
NGK TR6 plugs
Fuel system-
Transmission-
03 Cobra T-56
03 Cobra flywheel
Spec clutch
Exhaust-
