View Full Version : A/C Fittings - Long Pilot vs Short Pilot?
LemonTwisted
03-08-2016, 12:24 PM
I'm trying to find out what the difference is in using a long pilot EZ Clip A/C fitting versus a short pilot fitting. It looks like the depth of the O-ring is the same between the two versions except the depth that the fitting extends into the mating part is different. Does anyone know if both fitting types are interchangeable and what would be the advantages to using one type over the other?
dontlifttoshift
03-08-2016, 01:53 PM
You want the short pilot. I have run into issues with the long pilot not fitting into various bulkheads or aftermarket swedged aluminum hardlines before.
For our applications, I do not see an advantage to the long pilot.
LemonTwisted
03-09-2016, 10:12 AM
Good point, Thanks Donny!
