View Full Version : FS - Pypes exhaust 67-81 Fbody NEW
Donovan
03-01-2016, 07:28 PM
NIB - new uninstalled. Still in the bubble wrap.
This is the crossmember back exhaust. No crossover or X pipe. No head pipes.
Crossflow race pro muffler. 2.5"
Retail was $500 from Pypes.
$400 shipped inside the US
"This is the first system on the market with a true 'straight thru' flow path. That means that even though there is one muffler there is two completely separate flow paths for each side of the exhaust. There is absolutely no loss of flow thru the muffler. All other systems include a flow path that create turbulence and restricted flow in the muffler. This system has maximum ground clearance even on lowered vehicles. Great for even the highest performance(up to 600hp) applications where ground clearance and oem 'look' is a priority.
Pipes and muffler are 409 stainless steel. This is the last exhaust system you will ever need for your car."
124647
Dave@RACEWARE
03-02-2016, 05:03 PM
This system does come with an x-pipe from Pypes. Great system I have installed many of them.
Donovan
03-02-2016, 08:44 PM
Thanks Dave!
I want to make a note here. I purchased this setup without head pipes or an X-pipe. I already have the dual turbo muffler pypes exhaust and was going to add this to make it stockish quiet.
So this is only the pipes after the crossmember and no X-pipe.
