View Full Version : Question about hooker 42503hkr exhaust system
leturnracing
02-28-2016, 07:21 AM
Hello i got the 42503 hkr exhaust system for 67 camaro i m trying to figure how to install the hanger in the back, if someone got few pics it will be great thanks
leturnracing
02-28-2016, 07:24 AM
https://static1.pt-content.com/images/pt/2016/02/th_4608d7eb7fd8d2f7585a9e389731af16_zps1-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=4608d7eb7fd8d2f7585a9e389731af16_zps1al8yc 5h.jpg)those hanger goes on seatbelt bolt,https://static1.pt-content.com/images/pt/2016/02/th_6d0f2b8cc61f17bde76fbdf6397b124a_zpsq-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=6d0f2b8cc61f17bde76fbdf6397b124a_zpsqjtcfs 6c.jpg)and those on the rear frame rail , i try different way but doesnt seem fit
leturnracing
03-26-2016, 11:51 AM
I try few things , when i assemble the exhaust on the floor every hanger braquet are parralel, the passenger side seem finehttps://static1.pt-content.com/images/pt/2016/03/th_f9319cd4735323abeac1c53f6d02f4b2_zpsu-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=f9319cd4735323abeac1c53f6d02f4b2_zpsuft9x3 th.jpg)
On the driver side i think the hanger was weld the wrong way and should be the mirror of the other side ,like the black marker line.
- - - Updated - - -
https://static1.pt-content.com/images/pt/2016/03/th_240c924517d6ad5dc354a90219dbefa2_zpsq-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=240c924517d6ad5dc354a90219dbefa2_zpsqgw2nx us.jpg)
leturnracing
03-26-2016, 11:56 AM
Here another pic of the over axle tube, i try to figure if the rubber should go vertical or horizontal? My frame rail are new and i m not sure of the location of the other hanger https://static1.pt-content.com/images/pt/2016/03/th_eddfde35e8e411b831adb184d6bc8340_zpsf-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=eddfde35e8e411b831adb184d6bc8340_zpsf2j66o bl.jpg)https://static1.pt-content.com/images/pt/2016/03/th_c9ebb615bc7f7391b3f9ea3971922b5e_zpsa-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=c9ebb615bc7f7391b3f9ea3971922b5e_zpsaio4tf er.jpg)
Toddoky
03-26-2016, 12:42 PM
I can post some photos up for you on Monday if someone hasn't already done so by then...your muffler hangers that attach to the seat belt gussets seem to be on the wrong sides of the car, try flipping them one for the other.
leturnracing
03-26-2016, 03:10 PM
Yes ,pictures would be great thanks
Toddoky
03-28-2016, 06:47 AM
Here's a photo of the passenger side muffler hanger in its correct orientation on the seat belt gusset...the driver side sits on top of the gusset with the hanger rod pointing to the outside of the car in the same way.125413
leturnracing
03-28-2016, 08:50 AM
Thanks for the picture , i install the bracket with the black sharpie line on the driver side like you mention and its the same as your pics https://static1.pt-content.com/images/pt/2016/03/th_b357a762a1db881d997d19c3e129bbfd_zpsl-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=b357a762a1db881d997d19c3e129bbfd_zpsliivin 3o.jpg) so i try the other bracket on the driver side https://static1.pt-content.com/images/pt/2016/03/th_179e3db2009ebc14b90511e1d52abfb9_zpsk-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=179e3db2009ebc14b90511e1d52abfb9_zpsks26cq ei.jpg)https://static1.pt-content.com/images/pt/2016/03/th_144f0ad862ff3d2ed8a9de1fa8456da3_zpsl-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=144f0ad862ff3d2ed8a9de1fa8456da3_zpsljgpor wp.jpg)
leturnracing
03-28-2016, 08:54 AM
If the angle in the bracket go on the top of the seat belt gusset , the rod should be weld like the green tape on the brackethttps://static1.pt-content.com/images/pt/2016/03/th_66e8e0999ff1a58685826fdfbb6eeacd_zpsq-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=66e8e0999ff1a58685826fdfbb6eeacd_zpsqps3fz px.jpg) thanks again for the support
Toddoky
03-28-2016, 11:04 AM
thanks again for the support[/QUOTE]I just realized that the angular position of your gusset on the driver side is opposite of the gusset on the car that is depicted in the development file. Because of that, the possibility exists that the gusset on the other side of your car is also located with a slightly different location and I'm thinking it is due to the hanger rod angling upward slightly in your last photo. Is your car a Canadian built car? Here's the photo of the driver side hanger, which shows the opposite angle orientation of the gusset...125426
leturnracing
03-28-2016, 11:19 AM
Thanks for the pics and the answer, i change everything under with Autometaldirect product, maybe the seat belt gusset from AMD are different angle from factory , with your pics ,i can cut and reweld the bracket to fit my car . Thanks for your time
Toddoky
03-28-2016, 12:31 PM
Yep, that's the difference I believe...thanks for identifying the source of your floors, I'll have to send out a notice to the guys in Tech Service.
