View Full Version : So, how bad did I just hose myself? P-valve and lines above master (pic)
redmist
02-23-2016, 07:40 PM
So I spend all this time hand bending lines, and get things all mocked in and then realize I may have hosed myself when it comes time to bleed the brakes. I mounted my proportioning valve above my master by about 4 inches, and all the lines run to it.
Is this going to create a problem down the road? I will be using a Motive pressure bleeder when the time comes. I guess I could crack each line individually to get the trapped air out of the system, or will I be ok, and it will just push through?
thoughts?
https://static1.pt-content.com/images/pt/2016/02/IMAG0809_zpsxkcred3k-1.jpg
IMPALAMAN1
02-24-2016, 02:20 PM
Interesting.... Curious my self... But consider the old cars with the booster under the floor. At the rear end line it would be about the same distance above the master before the line drops to the rearend
68Cuda440
02-24-2016, 03:09 PM
I would be inclined to believe the air would like to collect up there, especially if there is a pocket or dead leg. Any reason you can't put it on the inner fender behind the shock tower.
icemanrd19
02-24-2016, 07:47 PM
use the art morrison bracket that i used.
redmist
02-24-2016, 08:31 PM
Not enough room there, I still have the starter relay there.
I wonder if residual valves are just needed? It's a lot of work to move it now, I might give it a try first.
*Sigh*
Skip Fix
02-25-2016, 01:27 PM
My Longacre brake pressure gauges came with a T fitting and bleeder set above the gauge. Wilwood bleeder setups I think are 1/8 NPT you could add one of them at the top of each line.
redmist
02-25-2016, 06:20 PM
Thanks for the ideas folks.
I think I may be able to A. Run or fab a bracket like noted above, and get the valve under the master. (Looks like some existing lines can be bent to make that run)
Or B. Bleed the system, and crack open each top fitting under pressure to release any trapped air.
I wish there was a Wilwood rep here! I am sure they could respond?
AMC Racer
02-26-2016, 09:37 AM
That will be tough to make work. Wilwood has a handy bracket and tube kit to mount their combo valve directly to the master if there's room ... but if you hadn't already bought their combo valve, just a proportioning valve in-line to the rear and mounted at the console would be more useful for tuning while driving.
Bracket kit:
http://www.wilwood.com/Search/PartNoSearch.aspx?q=220-13189
Can see it mounted here:
http://www.wilwood.com/Images/MasterCylinders/MasterCylinder_Photos-Large/tandem_master_kit_w_bracket-lg.jpg
Hope this helps.
icemanrd19
02-26-2016, 07:50 PM
buy the art morrison bracket that i have and then you can angle your lines under the master cylinder.
Motorcitydak
02-27-2016, 07:31 PM
The small size of the brake lines and the relatively high speed fluid travels when bleeding makes really any pocket of air difficult to stay put. In your case I would just recommend the old fashioned way of pumping the brake pedal with another person at each corner cracking the bleeder, that will give your fluid a higher velocity coming out and keep any air moving and on the way out. Nice job on the install BTW, looks really clean
Apogee
03-01-2016, 08:23 AM
While maybe not ideal, I wouldn't assume there's an issue until you bleed the system. There are several OE applications that I can think of where the hard lines are routed up and over the booster along the firewall to the passenger side rather than under the engine along the crossmember, so give it a shot IMO.
FWIW, I would remove the pressure switch and replace it with an 1/8" NPT plug if you're not planning on using it for anything. It would clean things up further and remove a potential failure point for the system.
Tobin
KORE3
