struck by Lightning
02-20-2016, 05:26 PM
Any suggestions and help is appreciated:
After WOT the RPM's will not come down?
1. I have added a ground wire to the carbs choke
2. Adjusted the float levels, they were slightly below sight glass center line
3. Checked for vacuum leaks, going to change the carb gasket just in case
4. Readjusted the idle mixture screws to achieve max vacuum
5. lowered the idle screw
Car idles and runs great at cruising speeds, no hesitation or surging.
Quickfuel SS-780-VS Carb
Automatic transmission
Any ideas guys?
Any ideas guys?
