BB69
11-03-2005, 11:08 AM
I have a 69 Camaro that I bought 3 years ago. Back then, I intended to buy a nice driver and have some fun with it. In reality, it needed a lot of work. I have spent the last 3 years just trying to get it on the road. I replaced all the suspension, updates to 4 wheel JL8 style brakes, replaced the subframe, and am now putting it together. Of course, while I was doing this, I really wanted to build a PT car. In fact, I have wanted to build a PT Camaro for longer than I can remember, obviously before there was a name for it. Long story short, I have decided I am going to sell the current car sometime next year, and start fresh. Whenever people ask questions about building a car, we all say to put your ideas on paper or you end up getting lost (something like above). So, I just got done roughing out my ideas for the next car. I thought I would share this as it may help someone else put a plan together for their car. Basically, I started with my goals; the things the car has to do or be. Then I added some detail to the goals. The final part is putting specific parts and ideas on paper to match the goals. I have a lot more to put down in this area, but it will take some time. I also would like to keep some ideas to myself for the time being. :ssst:
So here it is (please keep in mind many of the final details are missing, but I think the idea is there.) Some of the formatting is off from the original Word doc, so if it's confusing, I apologize. Hope this gives some people some ideas.
Brainstorm for Camaro
Main Goals
Handling
Comfortable
Must be turbocharged
Reliable
Clean appearance
Original
Affordable (originally and in service)
Details on goals
Handling
Lateral acceleration
Braking performance
Track days and backroads
Comfortable
Behavior of Car
Predictable handling
Slow transitions from under to oversteer
Stable under severe braking
Doesn’t follow road irregularities
No turbo lag
No pitching over bumps
Not bouncy over bumps
Little brake dive
Little body roll
Car environment
Supportive seat
Supportive restraints
Room for feet using pedals with normal shoes
Shifter within easy reach
Clear view from seat (front, side, rear)
Easy to read gauges
Easy to roll windows down
No rattles, buzzes, loose items
Readily accessible switches, controls
Heater/defroster
Smooth clutch action
Twins
Intercooled
Fuel injected
Wastegates
BOV
Reliable
Start every time
Cold
Hot
No overheating
Engine
Turbos
Diff
Brakes
Trans
No breakage
Clutch
Transmission
Driveshaft
Halfshafts if used
Differential
Engine
No fatigue failures
Rotors
Brake lines
Fuel lines
Roll cage
Suspension arms
Wiring (rubbing and chafing)
Clean appearance
No graphics
No special paint (candy, metalflake, etc)
Remove some trim (mainly badges)
Update some trim and exterior pieces (grill, door handles, side markers)
Integrate exhaust into body
Contrast
Combination of painted and polished/plated components
Black hoses and nickle fittings
Neat wiring
Reduce clutter
Engine bay
Dash
Original
Minimal purchased kits/components
Fabricate as much as I can
Benchmark as many cars as I can to combine/modify ideas
Affordable
Spread out purchases
Use production pieces
My labor
Minimal use of custom wear items (brake pads and rotors, bushings, shocks, sensors)
Invest in specialized tools (hydraulic tube flare)
Specifics to meet goals
Reduced weight
Remove rear seat
Lighter wheels
AL heads
AL radiator
Lighter seats
Rack and pinion versus steering box
Sheetmetal tunnel tied into frame
Fiberglass hood and fenders (possible trunk)
Reduced moment of inertia
Centralize items in center of car
Move engine back
Battery behind driver’s seat
Inboard shocks/springs
Move seats as close to console as possible
Push turbos to center of car (laterally and longitudinally)
Stiff
Full frame
Roll cage
Vertical and horizontal shear panels
All suspension points tied to cage
Consistent braking
Possibly manual for feel
Pad selection
Rotor diameter and thickness
Fixed versus floating caliper
Main Goals
Handling
Comfortable
Reliable
Clean appearance
Original
Details on goals
Handling
Braking performance
Comfortable
Behavior of Car
No turbo lag
Little brake dive
Little body roll
Car environment
Supportive seat
Easy to read gauges
Heater/defroster
Twins
Intercooled
Fuel injected
Wastegates
BOV
Reliable
Start every time
Cold
Hot
No overheating
Engine
Turbos
Diff
Brakes
Trans
No breakage
Clutch
Transmission
Driveshaft
Halfshafts if used
Differential
Engine
No fatigue failures
Rotors
Brake lines
Fuel lines
Roll cage
Suspension arms
Clean appearance
No graphics
Contrast
Neat wiring
Reduce clutter
Engine bay
Dash
Original
Affordable
My labor
Reduced weight
Remove rear seat
Lighter wheels
AL heads
AL radiator
Lighter seats
Move engine back
Stiff
Full frame
Roll cage
Consistent braking
Pad selection
