View Full Version : Airaiid U Build It 100-400 Tubing kit?
Tims 69
02-15-2016, 05:52 AM
Has anyone used these? Any pics of it installed in a 69 Camaro? Opinions? Quality?
reedld
02-15-2016, 11:45 AM
Here is a good one...
http://ls1tech.com/forums/conversions-hybrids/1267311-ls1-t56-69-ta-vert-4.html#post13928089
I bought airaid kit and did a similar tube build on my 1978. Key is to cut absolutely straight and use a commercial strength super glue. I bought a product from amazon but you can also purchase it at any hobby store.
Z06vet
02-15-2016, 02:32 PM
I have used them on 8-10 builds. I like them because they are easy, user friendly. I use black silicone couplers and stainless band clamps. That is extraordinary work in the link above. I just probably wouldnt go to that length on one of my personal cars because of the way I use them.
leturnracing
02-28-2016, 06:54 AM
https://static1.pt-content.com/images/pt/2016/02/th_e22465b4dcc7fa88a172662c67db22dc_zpsd-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=e22465b4dcc7fa88a172662c67db22dc_zpsduf3xo th.jpg) ls1 in a 67 camaro seem good quality for the price ,i m gonna put the 30 degree bend when i put back the fender and fab a heat shield. There almost enought tube for 2 air intake
leturnracing
02-28-2016, 06:56 AM
https://static1.pt-content.com/images/pt/2016/02/th_16e84fd516ee776d798ab42c81d26f5f_zpsi-1.jpg (http://s991.photobucket.com/albums/af38/Leturnracing/?action=view¤t=16e84fd516ee776d798ab42c81d26f5f_zpsixvya8 8l.jpg)
icemanrd19
02-28-2016, 10:30 AM
use super glue to temporally piece it together ( use it like you are tack welding it) to get the angle that you want. once you have all the angles set mark with a marker and then pull it back out and use high quality glue. Sand it down and paint. Simple as that. Mine turned out pretty good
https://static1.pt-content.com/images/pt/2016/02/12799306_10100772435270806_3652492576471-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/12799306_10100772435270806_3652492576471519004_n.j pg.html)
quarterbooty
02-28-2016, 07:43 PM
Looks real good. What glue did you use for the final assembly?
icemanrd19
02-28-2016, 07:53 PM
JB weld between the pieces and then once it dried and i sanded it down i then used some gorilla super glue around the seam and sanded that
quarterbooty
02-29-2016, 05:10 PM
Thanks for the info. I may give this a try.
Motown 454
02-29-2016, 09:13 PM
I just picked one up for my car. Check Advanced auto online I got just the tubing for $78
