TheJDMan
02-08-2016, 08:07 PM
I have two pics of two different SBC bell housings that I need to superimpose and adjust the transparency so I can compare the locations of the two clutch pivot holes. I think I can see a difference looking at the two pics side by side but I have no way to overlay one over the other to really make sure. I'm thinking that the pics may need to be resized a little bit to make sure the block mount holes or dowel pin holes line up. The reason I'm doing this is because I suspect the QT bell housing pivot mount is slightly lower than the Lakewood resulting in a difference in the angle of the clutch linkage. If I can determine a dimension, I'm thinking it may be possible to fabricate a new pivot mount bracket for the QT which will may hopefully correct the clutch linkage angles. Any help would be greatly appreciated.
https://rspimages.holley.com/15000.jpg
https://rspimages.holley.com/rm-6023pb.jpg
https://static1.pt-content.com/images/pt/2016/02/15000-1.jpg?width=583
https://static1.pt-content.com/images/pt/2016/02/rm6023pb-1.jpg?width=583
