gator68428
02-01-2016, 11:35 AM
(two weeks ago)
I have had the CPP big brake kit (front and rear) on my 68 Firebird for a few years now and thought it worked pretty well until I took the car to the track and realized the rears were not participating that much. I just changed to a 1" bore Wilwood master cylinder with rear prop valve. With prop valve wide open I still wasn't able to get the rears to lock up under hard braking. So I have no clue how much the rears were participating... Was hoping to get the rears to lock up then dial them back with prop valve... Yes i squeezed the e brake several times and bled the system properly.
Here is some video from the track. You can see the front tire smoke (at 1:35 and few more times after). Flat spotted the front tires pretty bad as a result (this is what lead to the Wilwood master with prop valve)
https://youtu.be/11HKzq5kHlo
Now tired of the cast iron front truck calipers with limited pad selection, I just upgraded to Kore3 C6 Z06 front kit and may have to go with a rear kit from him as well.
(yesterday)
But, in the interest of saving $$, I decided to devote one more day to trying to get the CPP rear brakes to function properly. I bought a pressure gauge to mount in the bleeder screw port to help (Tobin's recommendation). I have the 1"bore Wilwood master with cast dual reservoirs and rear prop valve kit (Willwood). Power brakes.
Full disclosure: I did not have the e-brake hooked up before two weeks ago (directions say you need to). But I did use channel lock pliers to squeeze the lever several times before my previous tests where I determined they weren't working properly. So, yesterday I hooked the e-brake back up and inspected its operation. I noticed the left rear cable (between caliper and frame mount) was a little bit kinked and wasn't engaging or disengaging fully. So i modified its forward mounting point to increase the bend radius and I oiled the cable. After that the left rear engaged more and released more. This issue was probably why I scrapped it in the first place (seems they do mostly release when cable kink minimized). Now it seems to keep the car parked and releases mostly. It will not lock the rear wheels up when I tried fully engaging it while moving--it acts as if you're gradually applying the brakes. But once stopped it's hard to start again until released.
I took readings with the pressure gauge in the front right caliper and the rear right caliper to compare and summarize the data below.
When pressing the brake pedal as hard as I can and assistant reading the gauge for me. Pressed 3-5 times for repeatability. Rear brake prop valve wide open.
Front right caliper pressure was 1000 psi with car off, 1500 psi at idle
Right rear caliper before e-brake installed: 1000 psi car off and idling
Right rear caliper after installing e-brake with improved cable routing, and eng/diseng several times: 1300 psi car off or idling.
(FWIW, pressure in RR caliper can get up to 1800 psi with e-brake engaged during test)
After the above testing I was pleased to see some improvement in the rear caliper pressure. So I took it for a test drive and recorded the below video to check the operation under panic braking.
https://youtu.be/llfsgcLAuR0
As you can see in the video, the front locks up first, followed by the rear. So now I at least know the rears are participating. But, while this may be preferred to have front lock up before rear, I'm still not fully happy because I would prefer the rears lock up first with prop valve wide open and then dial it back to the ideal amount. So I am still limited in rear brake proportioning control... But I will go with this for now and am at least happy to see some improvement.
Anyone have any similar experience with these brakes?
Why is the rear caliper pressure the same with and without the car idling?
What can I try next? Higher friction pads in the rear? SS braided flex lines in rear (SS up front, non reinforced in back presently)? (HP+ pads in front, and HPS HB580F.627 in rear) ...Only problem with that is the pad selection is limited with Lincoln Continental calipers...
https://static1.pt-content.com/images/pt/2016/02/20160131_122110_zpsf6t3e2xh-1.jpg (http://s393.photobucket.com/user/mitch_mac1/media/20160131_122110_zpsf6t3e2xh.jpg.html)
https://static1.pt-content.com/images/pt/2016/02/20160131_122120_zpsohqnmsxv-1.jpg (http://s393.photobucket.com/user/mitch_mac1/media/20160131_122120_zpsohqnmsxv.jpg.html)
https://static1.pt-content.com/images/pt/2016/02/20160119_205214_zpsrvgrgclr-1.jpg (http://s393.photobucket.com/user/mitch_mac1/media/20160119_205214_zpsrvgrgclr.jpg.html)
https://static1.pt-content.com/images/pt/2016/02/20160119_210413_zpsfvbf6qe4-1.jpg (http://s393.photobucket.com/user/mitch_mac1/media/20160119_210413_zpsfvbf6qe4.jpg.html)
(yesterday)
