View Full Version : Rivet nut tool
showdog75
01-31-2016, 07:19 PM
Curious if anyone here has used either the Astro Pneumatics rivet nut tool or the Harbor Freight rivet nut tool? I need one but don't want to shell out $200 for a tool that will likely be used for one or two projects. Would like to hear some feedback. Thanks
Jetfixr320
01-31-2016, 07:38 PM
I bought rivnuts and the tools that require you to manually set them with wrenches from McMaster-Carr. They work great.
68Cuda440
01-31-2016, 08:16 PM
I have the nice ratcheting style and the "cheap" type you use two wrenches to set. I have used both for projects at work. The wrench style is fine for low volume work, just more labor intensive.
Craig510
01-31-2016, 08:40 PM
http://www.mcmaster.com/#rivet-nut-installation-tools/=10xh9pv
They work pretty well as long as you grease the threads.
Motorcitydak
01-31-2016, 09:08 PM
Ive been using the HF tool for quite a bit now, have installed over 100 so far and counting. Most of them being 1/4 thread, some steel but more aluminum. I have had a few issues with it tho, the device that pulls on the rivet itself is pretty weak and failed, I had to weld it solid because of a poor design but since then it has been working like a champ and of course you can't beat the price
juggernaut
02-01-2016, 01:41 AM
I bought the westward brand one from grainger. It sets all the way up to 3/8". I've been satisfied with it for the price, It's large which is great for generating pulling powe. I can pull theads out of steel rivet nuts, so you have to be careful.
parsonsj
02-01-2016, 05:37 AM
I like these from McMaster too: http://www.mcmaster.com/#rivet-nut-installation-tools/=10xo5iy
For size 10 and 1/4" nuts, I use a 12V inpact gun and 7/8" wrench to set them. It works really well (nice uniform deformation on the back side), but it's not the right tool if you're going to install hundreds of rivet nuts.
TheJDMan
02-01-2016, 04:27 PM
I have the McMaste-Carr rivet nut pliers PN95585A600 for $56.28 which work exactly like pop rivet pliers.
http://www.mcmaster.com/#rivet-nut-installation-tools/=10xwj4b
gray86hach
10-03-2017, 05:32 AM
I have a marson tool it works great
Tim
GoodysGotaCuda
10-05-2017, 04:13 PM
I have the westward tool but it is very very large and hard to work with if you need to use it on the car. The harbor freight tool is only really good for aluminum rivnuts, which I am not a fan of.
I'll spend the money on a rivnut pneumatic gun someday...
rustomatic
10-05-2017, 07:08 PM
The Astro Pneumatic tool is awesome. I've been using it for months, and I keep finding new uses for the 100-pack of 1/4-20 riv-nuts I bought. What's better is that it does not fall apart after just a few minutes, like some H-F stuff tends to do. The A-P tool is a killer deal.
cpd004
10-06-2017, 03:45 AM
I have the Astro Pneumatic tool as well. It works great. I have been in a tight spot before though and the handles were difficult to fully open, but I managed to get it done.
MonzaRacer
01-08-2018, 11:17 PM
Tim
me too. metric and standard but biggest they handle are 3/8 10mm ant bigger require the smaller wedge style
AU Doc
01-09-2018, 08:12 AM
I didn't know these things existed, but now I have to have one!
