View Full Version : BOP rear axle question
boss_hoss
01-31-2016, 09:26 AM
For those of you that have worked on the Buick, Olds and Pontiac 10 bolt rear ends I have a question. When you install new outer axle bearings do you press them all the way on till they fully seat on the flange? That's what I did and I'm having some interference issues with my Right Stuff detailing signature rear brake conversion. Now when I install the rotor it comes in contact with the caliper bracket. Trying to decide if I need to modify the bracket for more clearance or move the bearing inboard a bit which sounds wrong.
Eric W
01-31-2016, 10:13 AM
Does this have the bolt in axle ends? I've got a 72 Olds, and the bearing actually presses past flush, with the seal protruding a bit.
Here's a couple pictures since I already have them uploaded. (I'm running Kore brackets and c5 calipers though)
https://static1.pt-content.com/images/pt/2016/01/20130401_192110_516-1.jpg (http://s989.photobucket.com/user/Wendteb/media/Cutlass/2013-04-01_19-21-10_516.jpg.html)
https://static1.pt-content.com/images/pt/2016/01/20130328_193213_29-1.jpg (http://s989.photobucket.com/user/Wendteb/media/Cutlass/2013-03-28_19-32-13_29.jpg.html)
Can see the seal sticks out slightly past the flange
https://static1.pt-content.com/images/pt/2016/01/20130402_213401_228-1.jpg (http://s989.photobucket.com/user/Wendteb/media/Cutlass/2013-04-02_21-34-01_228.jpg.html)
