View Full Version : Wheel fitment tools
badazz81z28
01-30-2016, 04:39 PM
Gents is there a better way to measure without the specialized tool? I see a member rents it, but considering I can buy one for less than his deposit and re-sell it for a less of a loss then rent/shipping cost thinking of just buying one. But can it be done without the tool?
Nine Ball
01-31-2016, 07:32 AM
You can measure wheels and tires with just two simple straight edged yard stick/rulers. I did it that way for years, before the fancy tools were even invented. There are only a few critical dimensions needed, for tire clearance and brake caliper clearance. These dimensions are here. http://www.forgeline.com/wheel_fitment.php
If you can provide that data, an experienced wheel/tire person can calculate the max tire widths front and rear, and what wheel size works. I'm here to help, if you need it :)
Tony
icemanrd19
01-31-2016, 09:44 AM
where are you located? I see you post on here a lot and maybe someone has a rim that they can send you to test fit. I thought forgeline use to do this if you buy their rims
Nine Ball
01-31-2016, 03:45 PM
I'm in The Woodlands, TX. About 25 miles north of downtown Houston.
No real way to send test-fit wheels, since they are all custom built to order. Careful measurements are needed, but luckily they aren't that difficult. If someone is local, I can always measure their car here.
Tony
badazz81z28
02-02-2016, 08:11 PM
I just ended up buying the fitment 45 tool. I may need some help using it when I get it.
badazz81z28
02-05-2016, 09:03 AM
Just got the tool yesterday....wow, not the highest quality I was expecting. Very rough porous casting and the hard ware came in a sandwich bag. I will be buying new hardware for it. It came with 1/4" tapered screws that don't sit flush with the mating surfaces. Weird for $400 tool.
mean buzzen half dozen
02-05-2016, 05:40 PM
Are these any good?
http://www.ebay.com/itm/Wheel-Tire-Combination-Measuring-Tool-Gauge-Fitment-Tool-Gauge-BackSpace-/111872026808?hash=item1a0c17a8b8:g:~aIAAOSwVL1WCVH B&item=111872026808&vxp=mtr
BlackMachOne
02-05-2016, 06:12 PM
That sucks! I was considering buying one. I'll rent your from you when you're done with it! I'll need one in a few weeks.
badazz81z28
02-05-2016, 11:36 PM
Gents, not sure what I'm doing. I mocked the tire up and DSEs 5.5" BS is not going to work. From what I can tell it will def hit the fender lip on hard bumps. I can't even get my fingers between the tire and the fender. Moved it in 1/4" and much better, 1/4" and More perfect. However with 6" BS super close on the inside near the tow hook. It clears, but not sure what the clearence would be with a rim. Am I expected to trim or roll the fender lip? 5.5" would work if I trimmed the lip....what am I supposed to do?
5.75? You don't have to use half inch increments for back space.
badazz81z28
02-07-2016, 09:21 AM
Yes, I'm actually overly concerning about this type of stuff. DSE says 5.5" but it looks like 5.75 is better, but is my difference because of tool variation?
