buster51
01-26-2016, 09:07 PM
Hi All,
New to the form as a member, but have been hanging around for a while. I'm especially interested in the suspension threads. I apologize ahead of time if this post is too long for a new guy.
I have a project that i'm in the planning stages of and looking for some opinions. We have a 70 AMC Rebel Machine that I originally did a quick restro to 30 years ago for our son's first car. It was pretty rough then and I had bought it for the drivetrain for my SC/Rambler. But he fell in love with it so I wound up making it safe and a decent driver. About five years later he hit something and ripped the upper control arm out of the (rusty) shock tower. So that was it and it moved from one storage place to another.
The car is completely original down to the ram air seal, 390, 4-speed and is black on black. I had somebody recently try to buy it mainly for the VIN and door tag because they were supposedly only 5 black on black left. The car is probably to bad to save, but I guess I don't know any better.
My thoughts have ranged from buying a clean four door or wagon to get a solid floor, frame rails, rockers and front clip, to a GM G-Body chassis or an Art Morrison frame. The first is pretty hard to do because there are almost no hardtops left and a sedan or wagon that is solid enough to use wouldn't be cheap and too nice to cut up. I got away from the G-body chassis because they look pretty flimsy and probably ruin the value of the car.
I like the Art Morrison, Chassis Engineering or Schwartz frames but am leaning to a CE rear clip and front IFS with Auto Weld custom bent frame rails. I also like the Scott's Hot Rod and Heidt IFS front ends. Progressive Automotive has a nice C4 system, but I'd rather run a traditional wheel style. The other option would be replicating the stock mounting points and using the Control Freaks AMC IFS like the excellent eddiebarret AMX build here.
My concerns are wheel travel and the ability to withstand a northeast pothole at 70mph. The car weighs 3500-3600 lbs. Most of the systems, if they mention it, only have 4" of wheel travel. The potholes are deeper than that. I also worry about the rear lower control arm mounts on Mustang II systems hanging out and the lateral load they have to withstand hitting a hole. A friend's Must II system failed when the upper control arm cross shaft T-bolts pulled through.
So, I'm asking for people's opinion on how any of these systems operate in the "real" world. I have searched here and read about ride quality, wheel travel and the amazing "Front Suspension & Steering Geometry" sticky, but am also concerned with handling bad pavement. It won't be a daily driver or a track car, but he will drive it to work and he isn't real good dodging road hazards. Any suggestions and thoughts would be appreciated. The car will be lowered 1-2 inches and use 16-17" tires, nothing extreme. It will use the stock style triangulated four link rear suspension.
Here's a early rendering. It will probably be more original looking now.
