sccacuda
01-22-2016, 08:17 AM
New In Box Quicktime RM-6071 bell housing.
Do you want to put a Tremec Transmission behind your small block Mopar? This Bellhousing will let you bolt a Ford TKO, T5 or TR3550 transmission to a 318 or 360 Mopar. Can be used for street, strip or circle track applications. 7.3 in deep bellhousing will clear the 130 tooth flywheel with 11 in clutch. Universal transmission bore will fit 4.85 in, 4.91 in, 4.685 in bores. Built from high grade steel, the cone is spun not stamped or rolled making this bellhousing dimensionally stable and accurate. Weighs 22 pounds. Fork bracket, block plate and Grade 8 hardware included. S.F.I. 6.1 approved.
$450 plus shipping or can be picked up at www.cjdautomotive.com (http://www.cjdautomotive.com/)
904-400-1802 Craig.
https://static1.pt-content.com/images/pt/2016/01/IMG_0381_zpsezraegig-1.jpg (http://s1060.photobucket.com/user/340cuda/media/IMG_0381_zpsezraegig.jpg.html)
904-400-1802 Craig.
