Ralph LoGrasso
11-01-2005, 10:12 PM
Perhaps this is a dumb question, but I'll ask it anyway -- Aside from spending hours at the track testing and tuning, or possessing an in-depth knowledge of suspension kinematics, how does one determine ideal aligment settings for their car?
For example, I'm going to be lowering my '01 SS in a month or so, and I'll be aligning it at that time, too. I want to go with something a little more aggressive than stock, but not too aggressive that I'll see uneven tire wear, or other adverse effects. Are there any "general" rules to follow when determing alignment setting, Ie add 2* negative camber to stock, 2* caster, etc. A bit more toe in, out, etc.
I should note that I have no prior experience in aligning cars, and I'll be using a rack to do it, not with hand tools. It won't be lowered much, only 1" or so, and I've also swapped 275/17s for 275/18s, but the OD is the same.
So, any general rules or guidelines to follow? I don't have the stock alignment specs, sorry.
