View Full Version : '67 Firebird/Camaro Front Wheel Size
JakeD
01-14-2016, 08:13 PM
Hello All!
I am looking into purchasing some wheels for my 67 Firebird. I have recently installed the full RideTech level 2 coilover kit with tubular UCA/LCA, 2" drop spindle, and RideTech Tru Turn. I am running the stock subframe.
Currently have 17 inch rim with a 275/45/17. No rubbing what so ever on the front end.
Looking to upgrade to a 18" rim on the front end. Is it possible to run a 18"x9" rim on the front end? Anyone out there doing it?
Jake
https://www.pro-touring.com/attachment.php?attachmentid=122261&stc=1
Schwartz Performance
01-14-2016, 10:23 PM
Tons of people run that. If I remember correct, back spacing should be 5-5.5" on a 9"
-Dale
JakeD
01-14-2016, 10:30 PM
-Dale
The front wheels I'm looking at have 6" backspace, so I suppose maybe I will have to use a half inch spacer or something..
b17brian
01-15-2016, 08:48 AM
How wide are your 17" wheels? Are you going wider on the 18"s?
JakeD
01-15-2016, 09:43 AM
I believe they are 17x8 but not 100% positive. I just don't want to to take off the tire just for the sake of measuring.
JakeD
05-13-2021, 09:52 PM
Hi guys,
Still looking to upgrade my wheels on the fire chicken....
I have a 67 firebird, mini tubbed and rear end shortened by 1" per side. Currently running on the rear: Size 17x11 Bolt pattern is 5x4 3/4 with a 6 1/4 backspacing.
In the front, not running anything aggressive. Something like a I believe they are 17x8 wheel with a 245/45/17 tire. Have ride tech suspension and tru-turn which should allow for a 10" wheel and 275 tire.
I would really like to go wide in the front (275 if possible). Considering staying with 17 or going 18 MAX.
I am in Vancouver, BC, Canada. Let me know what you guys have!
Thanks, Jake.
