View Full Version : Hurst Driveline Conversions has 6-Speed G-Body Kits!
Colby@HDC
12-30-2015, 11:47 AM
We've got complete 6-speed G-Body conversion kits (http://bit.ly/1J3dX64)! If you've got a 1970-1988 G-Body that you would like to drop a 6-speed Tremec transmission (http://bit.ly/1J3dX64) in, look no further. Post your questions below, or better yet, give us a call at 707-535-3030! 5-speed kits (http://bit.ly/1HQAcj4) coming soon....
https://static1.pt-content.com/images/pt/2015/12/841S8sF-1.jpg (http://bit.ly/1J3dX64)
Number1
12-30-2015, 02:19 PM
Are there any pictures of setup? Does it line up with factory center console placement?
olds87
12-30-2015, 11:10 PM
Do you have to raise the transmission tunnel up 2" or more for t56 magnum?
Colby@HDC
01-05-2016, 07:46 AM
We did not have to modify the transmission tunnel to get the trans to fit in the car. The shifter also lined up very good with the factory shifter hole. we do have pictures of the install in the car that we can provide to you.
Thank you,
olds87
01-05-2016, 11:34 AM
Can I get a quote on entire setup?
Samckitt
01-05-2016, 12:00 PM
If using with an LS engine, what motor mounts are required?
Mike@HDC
01-27-2016, 02:02 PM
If you would like a quote on a Hurst Driveline Conversion kit, please give us a call at 707-535-3030.
You will want to contact the company who manufactures your LS conversion kit regarding the engine mounts.
Streetbu
02-12-2016, 07:44 PM
Well thats the problem Mike. Each motor mount ends positioning the engine in a slightly different location. Which of course moves the transmission location. So what we need to know is which LS engine mounts to use in order to have your transmission properly located.........
Mike@HDC
02-19-2016, 08:38 AM
Any engine mount that will place the engine in the same location as factory will work.
Our senior tech and resident G-body guy, Ronnie, says that our friends over at UMI Performance make LS swap mounts which will work nicely with our driveline conversion kit.
Streetbu
02-19-2016, 08:53 AM
Thank you!
