Fbody
12-30-2015, 06:40 AM
1969 Pro Touring Camaro
Asking Price: $62,000
Included with the sale of the car is every receipt in 2 three ring binders sectioned off and categorized by Engine, Engine Accessories, Transmission, Brakes, Muffler, Fuel System, Exterior, Sound System, Wheel/Tires, Electrical, Front Suspension, Rear Suspension, etc. This same information is provided in a detailed Excel Spreadsheet that totals the build price in parts alone at $100,027.79. I can send this spreadsheet via email to serious potential buyers. Also included is a certified appraisal report that values the car well over my asking price. This too can be provided. I have an EXTREME amount of build information, pictures, etc.
Engine:
Scott Shafiroff Racing Engines custom build Dart 540 BBC.
Dart Big "M" 9.8" block with splayed 4 bolt main caps 4.56 inch bore, 4.25 stroke
Callies 4340 Dragon Slayer Forged Steel Crankshaft
Dart Pro 1 Aluminum Heads 325cc Intake Runner, 119cc combustion chamber w/ titanium retainers
SRP Pistons Forged Hi Silicon 9.9:1 Compression
Shafiroff Forged H Beam Rods 190,000 PSI
Pro Systems 1000 CFM Carb
Be Cool Radiator with Twin Spal
BBC Serpentine Belt System
MSD Digital 6 Plus Ignition System with MSD Blaster HVC Coil
Victor Jr Aluminum Single Plane Intake for 4150 Series Holley Carbs
Shafiroff Mechanical Roller grind 8620 steel billet
ATI Super Damper
Fel Pro Gaskets
MSD Pro Billet Distributor with Carbon Composite Distributor Gear
HIPPO Hi Pressure Pin Oiler Roller Lifters
Headers Custom Made from Lemons ceramic coated
Moroso CNC Billet Aluminum Hi-Volume Oil Pump
Edelbrock Victor Jr Perma Star finished Water Pump
Moroso Street Vacuum Pump
Advanced Plating Tall Hi Perf Valve Covers
All Stainless Steel Braided Hoses and Anodized A/N Fittings everywhere
Hyrdratech HydraBoost brake System with all stainless steel brake lines
Magna Flow Mufflers 3 inch exhaust with X Pipe
Built to Run on 93 octane pump gas
Actual Dyno Sheet 682 HP@6000 RPM, 648ft-lbs. torque @ 5000 RPM on 93 Octane Pump Gas
Transmission
Tremec T-56 Magnum 6 Speed
B&M Shifter
QuickTime forged Steel Bell Housing
Detroit Speed and Engineering T-56 Cross Member
Hydramax Hydraulic Clutch
McLeod Hydraulic Throw Out Bearing
Ceramic Clutch Rated at 750/lb tq capacity
Rear
Detroit Speed and Engineering Quadra Link with Ford 9" Axle Housing and 31 Spline Axles. Koni Adjustable Coil Over Rear Shocks
3.50 Gear Ratio
DSE Koni Aluminum Housing Coil Over Shock
Truetrac differential
Baer Track System Claw Rear Disc Brakes with Drilled and Slotted Rotors 13 inch
Detroit Speed Mini Tubs
Front Suspension
Chris Alston Chassisworks G Street Coil Over Conversion with Vari Shocks Double adjustable for rebound and comperssion. ShockWave upper and lower control arms
Detroit Speed Power Steering Pump Polished Aluminum
Detroit Speed Weld In Sub Frame Connectors
Unisteer Rack and Pinion
Interior
Corbeau Racing Bucket Seats
I have a Recaro Child Seat in the rear for my 6 year old
Painless Wiring Fuse Panel
Entire interior has Dynomat
JL 1 Inch Tweeter, 4.5 inch kick panel speakers, Infinity 6x9s, and Kicker 10in sub. 2 Kicker Amps. Alpine Receiver with I-Phone connector
Autometer NV Gauges
All New Carpet/Door Panels/Headliner
I Did It Tilt Steering Column
Flaming River Water Fall Steering Wheel
Detroit Speed Dash Insert wrapped in Carbon Fiber
New Glass New Seals
Billet Window Cranks
All New Dash Components
Detroit Speed 7 Speed Wiper Kit
Lokar Pedals
Exterior
Dupont 1999 Corvette Torch Red with Dupont 1997 Grand Prix White Stripes
Ring Brothers Billett Aluminum Hood Hinges
JW Speaker 8700 Evolution LED Headlights
ZL-2 Cowl Induction Hood sale of car also includes all Fiber Glass 4 Cowl Induction Hood painted to match
Detroit Speed electric headlamp conversion
Deroit Speed 19 Gallon Stainless Fuel Tank
Aeromotive A-1000 Fuel Pump
All Stainless Hoses on Fuel System and AN Fittings used everywhere
All New Bumbers, Drip Rail, Chrome Window Trim etc
Optima Yellow Top Battery located in the trunk mounted in Detroit Speed Billet Battery Holder
Video can be seen at: https://youtu.be/_nTvMsmVg_s
Engine:
ATI Super Damper
Fel Pro Gaskets
Transmission
B&M Shifter
Rear
3.50 Gear Ratio
Front Suspension
Interior
Autometer NV Gauges
New Glass New Seals
Lokar Pedals
Exterior
